Author Topic: charger to charge a 2.7volt capacitor at around 3Amoa  (Read 575 times)
Offline nickeevblog10Topic starter
« on: August 04, 2019, 10:42:02 pm »
I want to make one of these. I found some old kits no longer available but wondering can this be done, I do not have much money and I can solder and identify electronic components. To charge a 2.7V 500uF capacitor (I have the capacitor specification sheet).
Online ledtester
Re: charger to charge a 2.7volt capacitor at around 3Amoa
« Reply #1 on: August 05, 2019, 02:48:54 am »
A bench power supply is the most straight-forward way to do it:
A cheap LM2596 buck converter module should be good for 2A. You might be able to get 3A by using a better heat sink and active cooling. Here's a video which tests it under various conditions:
https://youtu.be/bK-yif8qqsc
You might get some additional ideas from this Julian Ilett video:
https://youtu.be/MdqJcrDiKN4
