Author Topic: Impossible Closed Ring Ferrite Transformer has No Visible Gap  (Read 1043 times)
Offline jonovidTopic starter
    • JONOVID
« on: December 03, 2020, 06:27:45 am »
just recently i have been re-using ferrite transformers by rewinding them for joule thief circuit testing.
rewinding ferrite transformers this requires splitting the two ferrite E and reassembling them with a new winding.
I came across this closed ring ferrite choke transformer! it has No gap in its ferrite ring  :-//
see for yourself! many switch mode power supply's have this type of closed ring ferrite choke transformer
on the AC input as an inductor used to block higher-frequency. so how is this type of transformer assembled? :-//
their is no gap in the ferrite ring.   and no band of tape to hold the transformer together.
most  ferrite transformers have two ferrite E with a gap,   a band of tape holds the  transformer together.
« Last Edit: December 03, 2020, 06:30:12 am by jonovid »
Hobbyist with a basic knowledge of electronics
Offline bob91343
Re: Impossible Closed Ring Ferrite Transformer has No Visible Gap
« Reply #1 on: December 03, 2020, 06:42:27 am »
The wire is threaded through by means of a toroid winder.  The bobbin the same.  I can't tell much from your pictures.
    • JONOVID
« Reply #2 on: December 03, 2020, 07:11:04 am »
ok more pictures  the bobbin is a single unit  and I tried to find a gap by scrapping and then breaking one to see how it was assembled
but no  :-//
Online BravoV
  • +++ ATH1
« Reply #3 on: December 03, 2020, 07:27:32 am »
If you observe carefully the plastic bobbin, its actually 2 pieces, and it has gear where to hook into powering gear to spin it for winding the wire, after it was clamped into solid piece of non gapped ferrite.
« Last Edit: December 03, 2020, 07:29:17 am by BravoV »
The following users thanked this post: fcb, blueskull, jonovid, Weston
    • JONOVID
« Reply #4 on: December 03, 2020, 02:31:20 pm »
thank you for help .
 I now know a little more about this component.  ;D
I did a little more disassembly. with a lot more care not to break the ferrite.  :phew:
thank you
Online BravoV
  • +++ ATH1
« Reply #5 on: December 03, 2020, 03:11:50 pm »
 :-+ :clap:
