Author Topic: Charging a supercapacitor  (Read 19480 times)
Offline SoftwareSamuraiTopic starter
« on: April 18, 2013, 02:54:11 am »
I've decided to start a little side project that involves using a supercapacitor instead of a rechargable battery. While I have read up on using supercaps, I'd just like to confirm a few concepts before I start. (For my experiments, I'm using a 400F 2.7V supercap.)
Q1: Am I correct that I want a constant-current circuit to charge a supercap?
Q2: Am I correct that the charging voltage should start out at whatever the supercap's current voltage is, and then be dynamically raised high enough to maintain the constant-current feed as long as the voltage across the supercap never goes above the supercap's rated value?
Q3: Am I correct that when using a supercap as an energy source, I should always add a little resistor in series (or perhaps a current-limiter) to prevent the load from pulling too many mA?
Any advice is appreciated!
Offline c4757p
  • adieu
Re: Charging a supercapacitor
« Reply #1 on: April 18, 2013, 03:00:25 am »
Datasheet? It differs from one to the next. Some don't require any limiting at all for discharge, as they can't deliver enough current to damage themselves, and only require limiting for charge if you need to avoid the inrush. Even if it does require limiting, I think that a CC circuit is probably gilding the lily a bit for most implementations. A resistor ought to be fine.
« Reply #2 on: April 18, 2013, 03:06:15 am »
The supercap I'm working with is the IOXUS RSC2R7407SR.
Offline BravoV
  • +++ ATH1
« Reply #3 on: April 18, 2013, 03:10:52 am »
Though just an EE wannabe, take my advise with a grain of salt ..
The need for constant current is just merely to avoid overloading the supply part, cause without a controlled charging condition (constant current), the supercap to the power supply is like a short circuit that will fry the charging circuit.
If the supply part voltage is "lower" than the supercap voltage, then it will discharge it's energy to the supply circuit, assuming there is no diode to block the backward current.
Supercap capable of sourcing huge current, the purpose of limiting the current is just merely a controlled energy discharge, like using a resistor as you mentioned or using a regulator circuit for more precise discharging mechanism.
Offline c4757p
  • adieu
« Reply #4 on: April 18, 2013, 03:16:02 am »
Jesus, that's one fancy datasheet...  ::)
With that kind of short circuit current I'd definitely be using a current limiting resistor, or at least a polyswitch. You could start a car with a few of these... Depending on how long of a charge time is acceptable to you, I'd either use a series power resistor, or a CC circuit delivering a relatively high current for faster charge. A 2A charge current will charge in 9 minutes, and a 0.27 Ohm resistor will give you roughly the same charge time.
With such a high charge current and power dissipation, you might also consider a buck converter. It's pretty easy to rig an MC34063 to give constant current. Assuming you're charging it from a 2.7V rail, you'll be dissipating over 3W over the first 2 minutes.
« Last Edit: April 18, 2013, 03:19:22 am by c4757p »
Offline peter.mitchell
« Reply #5 on: April 18, 2013, 08:12:56 am »
I'd re-wind a MOT, rectify it, put the rectifier on a big-ass heatsink, charge the cap with that :P
Offline Nickk2057
« Reply #6 on: April 18, 2013, 12:53:01 pm »
haha... you guys are nuts when it comes to those supercaps  :-DD :-DD :-DD :-DD but i guess those things are great to use (or abuse) in the work environment
just keep believing in yourself.. you can do some remarkable things in your life when you break through the ice and make things happen with the stuff you make
Offline c4757p
  • adieu
« Reply #7 on: April 18, 2013, 12:55:05 pm »
How so?
Offline smashedProton
« Reply #8 on: April 18, 2013, 02:08:05 pm »
Just make a charge pump ..
http://www.garrettbaldwin.com/
Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple.
Offline KD0CAC John
« Reply #9 on: April 18, 2013, 02:34:22 pm »
I need to go back to the tool storage , and look for something I bought from Snap On tools while I was a mechanic , and open it up again .
It was a small light jump-start box and used caps for jumpstarting , 12vdc up to 1600 amps , in order to use , it had to be connected to a supplied wal-wart to keep it charged , so not good for keeping in trunk , unless it was connected to the car's charging system , but again that wouldn't work , because if it was parked and needed , the unit wouldn't be charged , so shop use only .
Offline c4757p
  • adieu
« Reply #10 on: April 18, 2013, 02:42:31 pm »
I don't see how a charge pump is going to help you efficiently charge a 400F capacitor.  :-//
Offline AlfBaz
« Reply #11 on: April 18, 2013, 02:48:54 pm »
If the cap leakage is that bad you'd want to avoid having it in the boot, electron stains are really hard to get out of the carpet  ;)
Offline Nickk2057
« Reply #12 on: April 19, 2013, 01:42:30 am »
what I mean is that is one of those short circuits it will blow up in your face... and or cause a fire.... and like KD0CAC John said... "shop use only"... which sounds like a good warning since it will have a good fire extinguisher nearby..
Offline c4757p
  • adieu
« Reply #13 on: April 19, 2013, 02:16:14 am »
Eh, just stick a fuse on it. I'd go for a polyswitch - it'll have enough internal resistance to drop the short circuit current even before it trips. Not a big deal unless you go messing around before the fuse.
Offline Ferroto
« Reply #14 on: April 19, 2013, 03:40:11 am »
Be careful supercapacitors can deliver alot of current at relatively low voltages, here is a video showing how.
Useful calculator.
http://www.circuits.dk/calculator_capacitor_discharge.htm
« Last Edit: April 19, 2013, 03:47:10 am by Ferroto »
Offline Nickk2057
« Reply #15 on: April 19, 2013, 04:56:02 am »
Useful calculator.
now see... that is what I was talking about.... just so much energy in those things.... a lot of sparks from just a capacitor (or capacitors)
« Reply #16 on: April 19, 2013, 11:57:34 am »
I decided to try to charge up my 400F supercap and see what happens when I disconnect it and leave it alone for a while.
To charge it, I used an old PC power supply and the 3.3V rail and a tiny current limiter (300mA). I connected my meter across the cap and watched it slowly creep up to 2.5V. (Took a several hours.) Then I disconnected it completely. I've been periodically checking it now for some time.
@ 0 hours, 2.490V. (Just disconnected from the charging circuit.)
@ 8 hours, 1.936V.
@ 19 hours, 1.685V.
@ 34 hours, 1.640V.
@ 44 hours, 1.481V.
Q: Do supercaps really drop that much voltage over a ~48 hr period?
Offline Flávio V
  • Country: pt
  • Capacitor lover
« Reply #17 on: April 19, 2013, 06:31:24 pm »
The supercap should have retained near 2.2V in those 44H....when i charge my 350F maxwell ones after 8 hours they go from 2.7V to near 2.5-2.6V...so those super caps might be faulty or it is normal leakage...
Ioxus can leak at 1mA...the maxwell ones leak at 300uA(max or both)
Offline Nickk2057
« Reply #18 on: April 21, 2013, 02:03:25 pm »
hehe.... did it go boom yet?
anyways.. if it hasn't... congratz :-+ :-+
Offline chris.jarboe
« Reply #19 on: April 22, 2013, 02:50:59 am »
Samurai,
The initial leakage current for a supercap is typically high. The datasheet for the Ioxus part specifies 1.2mA for the leakage current, but this is "72hr leakage," or the leakage current after being charged for 72 hours. So yes, this is normal when they are new.
As for your original questions:
1) Absolutely correct.
2) Absolutely correct.
3) Ideally you want as little series resistance as possible, so I would start without it.
Good Luck!
« Reply #20 on: April 22, 2013, 11:52:41 am »
Thanks Chris.
So, when you say this is normal when they are new, do you mean that it will leak less after many charge/discharge cycles? (i.e. As it gets "older"?)
« Reply #21 on: April 22, 2013, 10:37:17 pm »
Yes. The leakage current will eventually be what you expect from the datasheet.
« Reply #22 on: April 22, 2013, 11:36:27 pm »
Interesting. That's not what I would expect from a capacitor.
I did contact IOXUS and they would like me to repeat my experiment and take measurements every 8 hours to double-check the discharge rate. Looks like I know what I'll be doing next weekend!
Offline jh15
« Reply #23 on: April 23, 2013, 04:08:04 am »
I bought a Coleman capacitor screwdriver just to have the concept in hand of capacitor power.
If I did not buy this product, I would think it was all vaporware. Great to demo to people. I drive many  screws, then complain, oh gee my screwdriver needs to be recharged... they expect it to take hours, it takes about 30 seconds.
Tek 575 curve trcr top shape, Tek 535, Tek 465. Tek 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P SBC, c-64's from club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15's. Heathkit ET- 3400a trainer&interface. Starlink pizza.
Offline Psi
« Reply #24 on: April 23, 2013, 04:32:48 am »
@ 8 hours, 1.936V.
@ 19 hours, 1.685V.
@ 34 hours, 1.640V.
@ 44 hours, 1.481V.
No, that's not normal.
My 2.5V maxwell 2600F caps take 1-2 months to drop from 2.5V to 2.0V and after that the loss is much slower.
I've got one here which hasn't been charged in ~6 months and its still at 1.8V
You either had something connected to the caps which was drawing current or your caps are faulty (perhaps small internal leakage).
« Last Edit: April 23, 2013, 04:40:15 am by Psi »
