Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
EDP to LVDS
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: EDP to LVDS (Read 663 times)
Xelef2000
Newbie
Country:
EDP to LVDS
on:
April 20, 2023, 09:54:29 am »
I am currently trying to replace the motherboard of an early 2011 MacBook Pro (a1286) with the motherboard of a framework laptop (
https://frame.work/marketplace/mainboards
), to save it from the landfill.
I am currently researching the feasibility of this project. I’m quite sure that it will fit space-wise (the MacBook is a bit wider and almost 1 cm deeper).
Thanks to the eevblog I also know how to hook up the keyboard and trackpad (
https://www.eevblog.com/forum/projects/making-a-standalone-usb-trackpad-from-macbook-pro-(mid-2012)-trackpad/msg4676602/#msg4676602
But I am currently struggling with the display since my knowledge of integrated display standards is lacking.
The MacBook display uses a 2 channel LVDS interface (
https://drive.google.com/file/d/1oK7pVRmHImKTNKWwxXv-sZcKGYWy38z2/view
The framework has two display output options, 4 lane eDP 1.4b, and Displayport over usb-c. I’d prefer to use the EDP output, to not take up more ports than needed, and to utilize features like display shutoff when the lid is closed and brightness adjustments from the OS.
I was able to find the PTN3460 bridge chip but it only supports 2-lane eDP up to DP 1.2a. (
https://datasheet.lcsc.com/lcsc/2106070806_NXP-Semicon-PTN3460IBS-F2MP_C2674387.pdf
My Questions are:
Can I use the PTN3460 and just drop 2 lanes and is it backward compatible (bandwidth shouldn't be an issue since the MacBook display has a lower resolution)?
Alternatively, can I use a standard DP to HDMI converter like the MCDP2900 with EDP, and what would be the best HDMI to LVDS chip afterward?
Logged
barshatriplee
Regular Contributor
Country:
Re: EDP to LVDS
Reply #1 on:
April 20, 2023, 10:15:00 am »
I think it's better to use an eDP to LVDS converter like the CH7511B.
https://www.silicondevice.com/file.upload/images/Gid655Pdf_CH7511B%20Brief%20Datasheet%20V1.13.pdf
Logged
Xelef2000
Xelef2000
Newbie
Country:
Re: EDP to LVDS
Reply #2 on:
April 20, 2023, 11:13:34 am »
Thanks, I haven't found this chip yet.
But it has the same limitations as the PTN3460, only to eDP lanes at 1.2.
I'm not sure if I can just not connect 2 of the 4 lanes from the mainboard and if eDP is backward compatible.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
EDP to LVDS
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
