Author Topic: connector id help  (Read 3236 times)
Offline BillStrachanTopic starter
connector id help
« on: March 06, 2024, 12:58:42 am »
i have a wiring harness for a 2008 chevy impala radio and there was a pin missing on the plug so im hoping maybe someone can tell me what the connector is called. there was a pin in a slot that wasnt used on my factory harness so i tried pulling it out to possibly re use it but the piece on the pin that keeps it held into the plastic connector broke off. i think the wire used is 20 gauge. i believe the connectors gm uses are made by delphi electronics. i appreciate any help thanks
Offline calzap
Re: connector id help
« Reply #1 on: March 06, 2024, 01:41:12 am »
Offline Jeff eelcr
« Reply #2 on: March 07, 2024, 01:47:57 pm »
If the AI housing is not wired correctly you may try Metra in Florida or a distributer of theirs elsewhere.
Most times quality is a better choice.
Jeff
Offline Nancy Guan
  • Country: cn
« Reply #3 on: May 15, 2024, 02:11:42 am »
I know that Delphi Electronic connectors, SQ connectors are sold, or have other questions you can ask.
E-mail:Nancy@suqinsz.com;
Whatsapp/Telegram:+86 17327092302;
Web:www.suqinszconnectors.com;
