Author Topic: simple diy intercom  (Read 560 times)
Offline amateur_25Topic starter
simple diy intercom
« on: August 19, 2019, 10:24:15 pm »
hi
i want to make a simple diy intercom based on this circuit. from a security point of view as we were recently robbed.
https://circuitdigest.com/electronic-circuits/two-way-intercom-circuit-diagram
however this is similar to how walkie talkie works which isn't what i want.
can i just omit the spdt switch then join the wires together so you can hear both mics at the same time?
The following users thanked this post: queennikki1972
Online fourfathom
Re: simple diy intercom
« Reply #1 on: August 19, 2019, 10:52:47 pm »
Yes, you probably can.  You might need to reduce the value of the resistor (R3) that feeds power to the microphones.  If you get horrible distortion try dropping the value by half.
Also, in that schematic there is a 10K resistor (R1) connected the the amplifier output, through a capacitor.  I'm pretty sure that resistor should be 10 Ohms, not 10K Ohms.  That's there to stop oscillations.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Offline Canis Dirus Leidy
  • Country: ru
« Reply #2 on: August 20, 2019, 10:32:34 am »
As variant:  slightly more complex scheme, but with sidetone cancellation (i.e. full duplex).
P.S. It's also more power-hungry, but this is due to the use of more powerful (1W) amplifier IC and loudspeaker.
