Author Topic: Cheap component tester Ebay UK Ideal for begginer?  (Read 1434 times)
Offline Terry01Topic starter
  • Country: scotland
« on: July 04, 2019, 01:36:27 pm »
https://www.ebay.co.uk/itm/AF-117-AF117-Transistor-TESTED-WORKING-Germanium-PNP/333176022934?hash=item4d92d6a796:g:tr8AAOSwAC1Z~0lB
I was scanning Ebay and came across this wee gadget....
I know they are just a cheap Chinese tester, but for a couple of quids must be worth a punt for a beginner ? ? ?
Sparks and Smoke means i'm nearly there!
Re: Cheap component tester Ebay UK Ideal for begginer?
« Reply #1 on: July 04, 2019, 01:49:19 pm »
I think that's for the transistor, not the tester.
  • Country: scotland
« Reply #2 on: July 04, 2019, 01:52:09 pm »
 :-DD
I think you might be right...DOH!!
Time for a quick 40 winks I think! LOL
Offline JamesAllen
« Reply #3 on: July 04, 2019, 01:53:28 pm »
If you search on eBay for Transistor Tester, there are literally hundreds on there that do a very similar thing.
I have one of the those DIY Kits with a 16x2 LCD screen which I soldered myself.
They are useful as a beginner but don't rely on values, they can be wildly out.
Thanks
James
« Reply #4 on: July 04, 2019, 01:56:44 pm »
:-DD
 :-DD ... If I'm honest I nearly bought one before I realised  :-DD
  • Country: scotland
« Reply #5 on: July 04, 2019, 01:59:55 pm »
That's well funny!   :-DD
Offline lordvader88
« Reply #6 on: July 04, 2019, 07:34:13 pm »
IDK about the 1 you're looking at, I don't see any spec's listed at all, or did I miss them ? At least buy 1 from someone that lists the chip, and what things it can test, like inductance or not.
Mine was $5-15 years ago, uses some ATmel micro-processor, and does measure ESR and inductance, as well as identify all kinds of 3 terminal silicon devices. But it never included probes tho. ESR function lets u test caps and see how leaky they are.
For a beginner they are great as a general purpose tester and ESR/LCR meter. And also still quite useful for testing transistors/diodes, especially un-readable ones.
Offline richnormand
« Reply #7 on: July 04, 2019, 09:06:46 pm »
I have a Tektronix 576 curve tracer to really check transistors but I have two of these inexpensive gizmos on the bench.
I end up using them more than the curve tracer or the ESR meter or the LCR meter.
They are great for a quick check and identifying unknown components.
They also make  mistakes and if the measurement needs to done better that is when I go to the real proper instrument.
I bought both without the case so I can solder surface mount devices on the board to test them (one has a few pads designed for that), also soldered miniclips (as shown in the ebay listing for your transistor) using a good length of wirewrap wire on the other. Very handy.
They are cheap ($15-20) and do vary in capability and programming versions.
So, yes, I would recommend one or two of these for someone starting up in the field.
« Last Edit: July 04, 2019, 09:12:25 pm by richnormand »
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline Mr.B
« Reply #8 on: July 04, 2019, 09:11:18 pm »
These types of testers are widely discussed in this 230 page thread: https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/
Offline vinlove
« Reply #9 on: July 06, 2019, 02:27:57 pm »
I have a tester similar to that one shown on eBay. I think I paid about  20£ a few year ago.
 Haven't used for a while.  Need to replace the battery.
It works well.
« Last Edit: July 06, 2019, 04:17:39 pm by vinlove »
Offline Vtile
  • Ingineer
« Reply #10 on: July 06, 2019, 08:58:44 pm »
Yep. There is also one of the project authors on that thread frequently discussing about the testers floating on the market.
Offline vinlove
« Reply #11 on: July 06, 2019, 11:13:01 pm »
I just took out mine from the drawer, and it is MK-328.
I have had it for about 5-6 years, and still works great.
