I have a few projects coming up where I want some of those cheap small panel mount DC Volt/Amp meters like these:
I have about a dozen different ones that I've ordered from China. The problem is that they all measure current on the "negative" side, like this:
For some of my projects I want these for, there will be a common negative to many devices (automotive stuff, PC bench power supply, etc). Does anyone know of a relatively cheap panel mount DC volt/amp meter that's roughly the same form factor that can measure current on the "positive leg" of the circuit? I understand why they design them to measure off the negative, and why that's a simpler/cheaper design, but wanted to see if anyone knew of some different models that measure differently.
Thanks!
