Author Topic: Cheap power bench supply, any recommendations?  (Read 473 times)
Offline Azhar
    • Youtube Channel
« on: August 30, 2020, 04:03:19 am »
I would like to buy one these cheap chinese bench power supplies, there are lot of models on ebay.
thought of asking you see if you can recommend any brand/model!
thanks
Offline ledtester
Re: Cheap power bench supply, any recommendations?
« Reply #1 on: August 30, 2020, 04:13:50 am »
For a switching supply, 0-32V 0-5A the Gophert NPS-1601:
https://youtu.be/bSkeV2ezuBs
Online ataradov
    • Personal site
« Reply #2 on: August 30, 2020, 05:20:02 am »
I would not cheap out. The most generic 30 V, 5 A power supply from eBay/Ali is about $50.
KORAD KA3005D is $100, but a way better power supply in all possible respects. I would strongly suggest just getting it and not worrying about what you get from the cheap ones.
KORAD is also linear, so no noise issues and much better reaction to variable loads. Having presets and digital controls makes it much harder to accidentally change the voltage/current.
« Last Edit: August 30, 2020, 05:22:15 am by ataradov »
Alex
Offline JustMeHere
« Reply #3 on: August 30, 2020, 06:07:17 am »
I like my TP3005P.  The price is a bit up right now.
Offline Electro Fan
« Reply #4 on: August 30, 2020, 06:42:45 am »
+1
Korad KA3005D
Offline ercapoccia
« Reply #5 on: August 30, 2020, 07:38:54 am »
If you not need a linear programmable power supply, Gophert NPS-1601 is excellent for the price.
Offline radiolistener
  • Country: ua
« Reply #6 on: August 30, 2020, 10:50:26 am »
+1
KORAD KA3005D very good linear power supply with precise output.
This is linear power supply and have no switching noises like Chinese switching power supplies.
Offline wizard69
« Reply #7 on: August 30, 2020, 09:13:06 pm »
It might help to tell us what you will do with it.
The cheap Chinese power supplies can be pretty dismal if you are not careful.   As such I wouldn't suggest any model that isn't from an established company with a track record.   Further you effectively throw away your money on such products because when the do fail warranty repair is a joke.   Even repairing them yourself can be problematic due to low quality and hard to find parts.    I just don't see an advantage here in most cases.   A decent power supply should last years.
More importantly to me is that people end up buying supplies that they really don't need and at the same time pass up the opportunity to build a supply themselves.
You may ask why is it important to build a power supply.    Fairly simple as supplies are a common failure point in electronics and understanding them is important when it comes to digital stuff.   Or to state it another way it is a valuable asset to understand how power supplies work and fail, when working on digital circuits and designs.
thanks
