Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Cheap ESD Flooring
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Cheap ESD Flooring (Read 974 times)
ocset
Super Contributor
Country:
Cheap ESD Flooring
on:
June 12, 2018, 06:06:52 pm »
Hello,
We need ESD flooring for our electronics assembly lab.
We will use these ESD floor tiles, they have a resistance of 100 billion ohms per metre^2...
https://www.antistaticesd.co.uk/shop/anti-static-esd-mats/heavy-duty-esd-7mm-interlocking-tiles/
...so we will put loads of strips of conductive tape beneath them and earth those.
Please could you help review this?..it is as in the attached document
Last Edit: June 13, 2018, 05:06:40 am by treez
Logged
JourneymanWizard
Newbie
Country:
Re: Cheap ESD Flooring
Reply #1 on:
June 12, 2018, 08:26:39 pm »
This may help answer your questions:
https://www.staticworx.com/articles/the_basics_of_esd_floors.php
How is it being used (heel clips and conductive shoes? civvies?), and can it effectively be grounded from the back?
What is your sensitivity? Can you handle higher risk (e.g. 1kV risk), or are you dealing with sensitive (a few hundred volts) or very sensitive parts (a few tens of volts - probably not, unless you are wire-bonding)?
There are some resources at Desco, the ESD Association, and others, including the ESDA article reproduced in a magazine linked below
http://sites.csn.edu/slots/ET138B/appendix_b_electrostatic_discharge.htm
Logged
ocset
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Cheap ESD Flooring
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
