You can use 1:100 probe (2000V at DC), it has better limit at RF, about 50V or even 100V at low frequency band.
Another way is to use high power RF attenuator. It allows to see signal with less distortions like it happens with probes.
This is exactly what i was considering. A 1:100 probe will be next on my shopping list. Will also shop RF attenuators if the budget allows. Expansion of ones probe collection can never be a bad thing.
A scope is pretty much useless for RF, you'll see "something", but that's all, no measurements for power, armonics, modulation...
You need a RF analyzer for that!
But isn't the 11 meter band in America between 26.965 and 27.405 well enough below the -3db point for a 100MHz scope that decently accurate measurements can be taken? Then manually calculate average/peak envelope power if one were without the equipment to measure it? Modulation can be observed quite well for reference purposes IMO. You can definitely see if your radio is over/under modulating and make adjustments. As for harmonics, i have the Siglent SDS812X HD so wouldn't the 2Mpts FFT get you a vague idea of where your power is going? At any rate, you're right, one could definitely get better measurements from specialized test equipment. But i'm a tinkerer on a tight budget. Way to tight for this kind of hobby
but i've been into electronics since i was a kid and i enjoy it.
There are some probes more suitable for this kind of application. I use ELDITEST GE3425 (GE3421 and GE3422 are OK too in this respect)
Cheers
Alex
Not a bad price, thanks Alex.
Even the cheapo switchable 10:1 probes I don't trust at any dangerous voltage level typically include a derating curve on the datasheet in the bag along with the other accessories. IIRC most start to drop just past audio frequency.
Neither do i at this point. The Siglent PP510's that came with my scope start at 300V rms and drop off rapidly. But the PP510's i just looked up on there website are completely different according to the data sheet, they start at 600V and don't start dropping off until around 20kHz higher than the ones that i have.
In the other thread we have an example of derating for a 10:1 probe rated for 300 V.
That is a really close match to the siglent PP510's that came with my scope i believe. BUT, not the ones you find in a search for the same model on their website.
Back to the subject at hand. I took the time to dig further through the spec sheet
https://siglentna.com/wp-content/uploads/dlm_uploads/2024/06/SDS800X-HD_Datasheet_EN01D.pdf for my scope and found: Max. input voltage 1 MΩ ≤ 400 Vpk (DC + AC), DC ~ 10 kHz. So i'm still wondering about frequencies greater than 10kHz directly on the scopes inputs. However, one would do good to keep within the limits of the probe you're using as the probes job is to attenuate high voltages. And as others have stated, use the proper attenuation when dealing with high frequency + high voltage measurements. Know your probe, know your equipment, when in doubt, attenuate it out.
