Yeah that.
I don't worry so much about the polynomials, as they're a solved problem, and there are calculators to transform their solutions into the approximate RLC values I need (that, because of factors not accounted for, often need further tweaking anyway). I'm satisfied with knowing the underlying mechanics: poles on a circle/ellipse/etc. for the various conditions, or some variation on that for other purposes (there are many other possible optimization goals; some even just arise from what's convenient in a given topology).
But I will add in regards to that, you can get a 3-pole single stage pretty easily. The values are screwed up, it's not simply putting an RC in front of a 2-pole stage; but they can still be calculated, and have enough freedom to allow for most (all?) Q factors a stage might need.
http://sim.okawa-denshi.jp/en/Fkeisan.htmNote that the response still depends on source impedance, so it may be desirable after all to put a buffer in front, which still ends up needing 3 op-amps; but this is better than the 4 that would be needed for a buffered 1/2-pole chain. Heh, also not that it saves much in practical terms, given that amps come in duals and quads, but this can be helpful in stereo/multichannel systems.
