Author Topic: check of circuit diagram  (Read 1198 times)
Offline glinjikTopic starter
« on: January 21, 2020, 12:49:40 pm »
hi i am thinking of building this for fun and expand my knowledge of smps but i think i found a error I've highlighted the problem cap i think it should be an x2 cap probably 275v 0.47uF but unless im reading this wrong 1kv 0.47n unless its a big disk cap the nearest i have is 1.6k 4n7 but kv seems a bit on the huge side ?
All the truth in the world adds up to one big lie (Bob Dylan)
Re: check of circuit diagram
« Reply #1 on: January 21, 2020, 03:53:42 pm »
ok think I've sussed it out myself 1kv is the part code 1.4n is the value its the blue type disc caps bit confusing on the diagram live and learn
Offline Vovk_Z
  • Country: ua
« Reply #2 on: January 21, 2020, 04:12:19 pm »
No, not X2. I think there isn't errror. It's snubber circuit, rated voltage is 1 kV or more, 4700 pF capacity.
You can check youself at some FSDM311 related application notes.
« Last Edit: January 21, 2020, 04:15:23 pm by Vovk_Z »
The following users thanked this post: glinjik
Online Gyro
« Reply #3 on: January 21, 2020, 04:30:06 pm »
The 104 code is 100nF, not 1.4nF (it stands for 10 followed by 4 zeros pF).
For 4n7 you want a code of 472 (47 and 2 zeros pF).
Best Regards, Chris
« Reply #4 on: January 21, 2020, 07:12:33 pm »
another question at L1 10uhn is this supposed to be 10uh?
Online Gyro
« Reply #5 on: January 21, 2020, 07:28:20 pm »
It looks like it, Henry is upper-case by the way... 10uH.
Best Regards, Chris
« Reply #6 on: January 22, 2020, 04:29:52 am »
thank you i WilL tRy tO RemembEr tO uSe caSes CoRectLy  :-DD
« Reply #7 on: January 22, 2020, 11:16:18 am »
Hi can someone tell me if I've got this filter correct not the values just the wiring
Offline Vovk_Z
  • Country: ua
« Reply #8 on: January 22, 2020, 11:50:21 am »
No, it is not correct. And I don't see a reason to design your own filter (they are not a secret now, but I'm not sure how it is in Russian Federation now).
« Last Edit: January 22, 2020, 11:52:56 am by Vovk_Z »
« Reply #9 on: January 22, 2020, 12:21:39 pm »
i won't answer that smart comment, this is an electrical forum not a place for cheap political digs
« Reply #10 on: January 22, 2020, 05:55:46 pm »
Well i decided to add a choke to the circuit after a bit of reading i came up with this i plugged it in for the first time and no bang put the fluke across the bridge rectifier 116vdc scary stuff a transformer at 12v is one thing this is new territory i hope the choke is correct it's the same choke and caps that were feeding the transformer in the pc ATX so no need to calculate the choke or caps is that cheating a bit?
