Author Topic: zener diode question  (Read 1866 times)
Offline m3vuvTopic starter
« on: February 09, 2022, 03:38:44 pm »
Hi all,i need a 6.2v zenner,but i only have one that zeners at 7.8v,if i add a couple of silicon diodes and a shottky in serries with it ie say 1.5v drop assuming silicon 600mv drop and a shottky at 300mv,would that work as a 6.3v zener ?
Re: zener diode question
« Reply #1 on: February 09, 2022, 03:39:43 pm »
6.3v would be near enough .
Offline TimFox
« Reply #2 on: February 09, 2022, 04:53:32 pm »
No.  Your combination would increase the total voltage across the diodes from 7.8 V to approximately 7.8 V + (2 x 0.7V) + 0.3 V = 9.5 V.
Offline Terry Bites
« Reply #3 on: February 09, 2022, 06:47:37 pm »
That will increase Vf to where you want it but it won't be as stable as a zener made for that voltage.
In fact, it will be a very poor zener.
Offline TimFox
« Reply #4 on: February 09, 2022, 07:11:36 pm »
He has 7.8 V, but wants to decrease it to 6.2 or 6.3 V.
Offline ledtester
« Reply #5 on: February 09, 2022, 07:22:59 pm »
The OP should explain how the zener is being used.
It is possible the OP wants to create a 6.3V power supply by first creating a 7.8V power supply with the zener on hand and dropping the voltage with some diodes. This requires a consistent current draw.
If the intent is to create a reference voltage into a high-impedance input, well, that's another story.
Offline TimFox
« Reply #6 on: February 09, 2022, 07:29:45 pm »
He did say how he meant to connect them (in series to make a “6.3 V Zener”) but he apparently thought that the additional diodes would have a reversed polarity voltage,  possibly due to the reversed symbols for the forward-biased added diodes and the reverse-biased Zener.
Offline Zero999
  • 0999
« Reply #7 on: February 09, 2022, 07:46:49 pm »
What are you trying to do? If you want a voltage reference, then there are various tricks, to do that. If the output impedance is not important, simply add a potential divider. If you need a lower impedance, add a couple of silicon diodes in series with the load.
« Reply #8 on: February 09, 2022, 08:47:26 pm »
forgot to say,i also have a 5.1v zener,its for d10 in attatched schematic,the kit came with it missing.
Offline TimFox
« Reply #9 on: February 09, 2022, 09:07:01 pm »
Two forward-biased 1N4148 (or similar) PN diodes in series with a 5.1 V Zener would give about 6.3 to 6.5 V.  5.1 V Zeners have a reasonably low temperature co-efficient, and the two forward-biased diodes would degrade that somewhat.  (Temperature-compensated reference diodes comprise a Zener and one or more forward-biased diodes in series, where the opposite-direction temperature co-efficients cancel at a specified value of current.)
« Reply #10 on: February 09, 2022, 10:17:26 pm »
so would a normal pn diode with the 5.1v zenner work in place of d10 then in this psu that schematic i posted? TIA
Offline magic
« Reply #11 on: February 09, 2022, 11:26:49 pm »
It looks to me like this diode sets negative supply to some LM358 and also reference voltage for CC mode.
The latter is dodgy due to thermal drift of such zeners. 5.1V would actually be better for that, or two TL431 in series or TL431 with feedback dvider to get 6.2V.
I can't see anything immediately wrong with reducing supply voltage of those opamps to -5.1V but I haven't analyzed the circuit thoroughly.
Anyone? :-//
BTW, what's J1 and J2?
edit
Nevermind. If you add two diodes to a 5.1V zener, you get 4mV/°C drift (assuming perfect zener) which is 0.06%/°C or 0.6% for 10°C. Who cares, just do it.
« Last Edit: February 09, 2022, 11:35:42 pm by magic »
« Reply #12 on: February 09, 2022, 11:40:44 pm »
As far as i know j1+j2 are the connectors for the voltage and current adjustment pots,i will give the zenner a go,at least it may be ok untill i can order the correct one .
Offline magic
« Reply #13 on: February 09, 2022, 11:49:45 pm »
I suppose 5V would work, those LM358 only need to sink current from power transistor's base through a few diodes and it looks like their output voltage is near that floating ground (which tracks the OUT+ voltage). The CC one needs to overcome Vf of an LED, so it's a bit harder.
Worst thing, there will be no regulation. And the range of CC adjustment may be a bit narrower if regulation does work. That could be fixed by tweaking those resistor dividers.
edit
And whoever drew that schematic must have been drunk. Why are LM358 power supplies upside down?
« Last Edit: February 09, 2022, 11:53:01 pm by magic »
Offline magic
« Reply #14 on: February 10, 2022, 03:04:05 pm »
It's a dodgy circuit. Two problems with it:
1. As pots wear out, they may lose contact between the wiper and the track. When that happens, this PSU will output maximum voltage.
2. If you manage to set the CV pot to 0Ω very fast while there is still voltage on the output (or if something fails and the output loses regulation), the output will discharge through D10, a parasitic diode inside LM358 and the CV potentiometer - not a great idea.
I would mod it: connect the pot's track to J2 as intended, then separate VR2 and connect it to the wiper with a third wire.
Offline TimFox
« Reply #15 on: February 10, 2022, 03:24:06 pm »
A quick look at Mouser indicates that, for example, 6.2 V 500 mW Zeners in onesies cost $0.16 (USD).  That one, BZX79C6V2 is available from several manufacturers, in stock at Mouser, with different suffices.  Perhaps that is a better solution to your repair.
Offline magic
« Reply #16 on: February 10, 2022, 03:58:25 pm »
What makes you think that a 6.2V zener would be a better repair than a 5.1V zener?
Reminder: the designer of this PSU kit probably wasn't entirely sober :)
Offline TimFox
« Reply #17 on: February 10, 2022, 05:20:34 pm »
The words "for example" in my post indicate that Zener diodes in that voltage range and power are available at very low prices.  The 6.2 V device was an example.  If you read his original post, he was trying to produce a 6.2 V Zener from multiple components.
Offline w2aew
    • My YouTube Channel
« Reply #18 on: February 10, 2022, 09:02:03 pm »
How about using a Vbe Multiplier circuit - you can dial-in the drop you'd like:
https://youtu.be/Obh_PIC2qqo
FAE for Tektronix
Offline TimFox
« Reply #19 on: February 10, 2022, 10:13:57 pm »
Vbe multipliers need three components and are temperature sensitive.  With that number of components, a TL431 would be a better choice.
Replacing a Zener diode (two wires) with a cheap new Zener diode will fit the PCB better.
