Author Topic: CHECKING A 6S BMS  (Read 440 times)
Offline silly sausageTopic starter
CHECKING A 6S BMS
« on: January 15, 2025, 10:58:39 pm »
Hello,a few months ago  repacked my clansman prc-320 rad battery with lion colbalt 18650 cells, left it on rx as a test, long story short tthe bms did not cut off so runed he cells,i have a new bms and set of cells,is there any way to test thee low voltage cut off?,all i have is two 0-30v lab psu's,i dont want to kill the new cells,cheers tony.
Offline m k
Re: CHECKING A 6S BMS
« Reply #1 on: January 24, 2025, 05:50:45 pm »
You can mimic cells with resistors.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
« Reply #2 on: January 26, 2025, 03:10:29 am »
what value resistors do i use?.
Offline m k
« Reply #3 on: January 26, 2025, 04:53:42 pm »
The value where voltage over single resistor is a bit under cut-off.
The following users thanked this post: silly sausage
