This type of oscillator is hardly the place to begin with understanding electronics. It will make a useful demonstration.
I am discovering that finding the right path to electronics from understanding a circuit with a couple of resistors and a battery etc to something more substantial, is quite hard; give me time…..
I am looking forward to trying the oscilloscope on these little circuits.
Once you can sling AC and DC circuits around, you should start looking at active circuits - something with a transistor that amplifies. w2aew has some videos on the topic and they are very good.
Try this one on for size:
https://youtu.be/zXh5gMc6kyUYou can search for the others in this list:
https://www.qsl.net/w2aew/youtube/W2AEW_video_index.pdfAC circuits has the difficulty of imaginary numbers and gruesome impedance calculations. Fortunately, we have Octave and MATLAB and these programs know quite well how to deal with
i.
i is just a 90 degree phase shift and comes up in every AC circuit with reactive components.
Attached is one of my favorite examples using an Analog Discovery 2 with a 10k resistor and 0.1 ufd capacitor as a low pass filter. Given floating inputs, I can get current by measuring the voltage drop across the resistor and voltage by measuring the voltage across the capacitor. And, of course, the AD2 provides the 1 kHz sine wave.
You will probably run across the phrase "ELI the ICE man" where E leads I in an L (inductive) circuit and I leads E in a C (capacitive) circuit. We expect I to lead E in a low pass filter and indeed it does.
Simple circuits are fun to play with. I can take the same components, wired the same way (low pass filter) and hit the circuit with a square wave and verify the capacitor charge/discharge function. See attachment 2
Or, I can look at the Bode' plot of the low pass filter. The cursor is off just a touch, it should be at the -3dB break point and it's at -2.9... See attachment 3
I can spend hours playing with simple circuits! There's a reason I am a strong supporter of the AD2 but I certainly don't like the new and improved price.
