Author Topic: Identify speaker  (Read 1585 times)
Offline fixit7Topic starter
Identify speaker
« on: May 25, 2019, 04:18:37 pm »
This is from a cordless phone.
I think it is a speaker.
Phone uses 2.4 volt battery.
I was wondering if it would work in a 9 Vdc circuit?
https://www.dropbox.com/s/yy6rwm0vib91010/PhoneSpeaker.jpg?dl=0
Online PA0PBZ
Re: Identify speaker
« Reply #1 on: May 25, 2019, 06:45:20 pm »
Yes it is a speaker, and the characteristics are printed on it. Since a speaker is driven with AC your question about 9V DC is irrelevant.
Offline mikerj
« Reply #2 on: May 25, 2019, 06:54:50 pm »
Not entirely irrelevant.  A 9v pk-pk signal across that 150ohm speaker would be around 68mw, more than double it's rated power.
A high impedance driver like that could be driven directly from the output of an op-amp.
« Reply #3 on: May 25, 2019, 08:42:14 pm »
Was not aware it was an AC speaker.
Online Zero999
  • 0999
« Reply #4 on: May 25, 2019, 10:14:39 pm »
All speakers need to be driven from AC. The sound they produce mirrors the AC waveform. For example put in 1VAC at 1kHz and it will produce a 1kHz tone. There are limits of course the the upper and lower ends of the frequency response. This telephone speaker is probably only good for a narrow frequency range of 300Hz to 3kHz.
The only things which beep and work off DC are buzzers, basically a simple speaker with a built-in oscillator which converts the applied DC voltage to AC to drive the speaker. The oscillator in a buzzer can be either electronic (normally just a transistor with feedbacl) or electromechanical: basically a relay with a normal closed contact wired in series with the coil and the moving iron attached to a diaphragm to improve the coupling of the vibrations to the air.
The following users thanked this post: fixit7
« Reply #5 on: May 26, 2019, 12:44:30 am »
Thanks.
I have one of these. Does it run on AC?
What is the 5Vp-p?
Piezo Transducer
Electrical Specifications:
    Rated Voltage: 5Vp-p
    Rated Current: 2mA (max)
    Sound Output at 10cm: 85 dBA
    Resonant Frequency: 2.04kHz
Offline timelessbeing
« Reply #6 on: May 26, 2019, 02:09:56 am »
Vp-p = Peak-to-Peak voltage
Are you trying to make something, or just taking things to bits to see what they do?
http://www.bcae1.com/audoutex.htm
http://www.bcae1.com/speaker.htm
« Last Edit: May 26, 2019, 02:13:16 am by timelessbeing »
« Reply #7 on: May 26, 2019, 02:50:22 am »
I made this circuit on a experimenters breadboard.
After I knew it was working, I soldered the components to one of these.
PCB Prototype Circuit Solder BREADBOARD - Discrete and DIP
https://makezine.com/projects/laser-tripwire-alarm/
I made some modifications by adding a piezo buzzer instead of a plain speaker.
I also had to put a 3 inch piece of PVC pipe over the Cadmium PhotoCell to keep non-laser light from affecting the circuit.
« Reply #8 on: May 26, 2019, 04:03:23 am »
does it work?
Online Zero999
  • 0999
« Reply #9 on: May 26, 2019, 07:20:11 am »
That circuit requires a buzzer to work. It will not work with plain speaker or piezo transducer which doesn't have an internal oscillator. It it works, then you're using a buzzer - well done!
« Reply #10 on: May 27, 2019, 02:29:45 am »
does it work?
Yes, both the circuit and buzzer work.
The diagram was from the author of the circuit.
I am learning to use Geda to create my own circuit diagrams.
I looked for a symbol for a piezo buzzer. The closest I found looked like a speaker with plus and minus terminals.
It was quite a leaning experience going from the solderless breadboard to soldering the components in the final board.
Learned a lot and it will take quite a bit of practice to get good.
I will eventually need a temp controlled iron as my "Hakko knockoff" was overheating as the dial readings did not correspond to the actual tip temperature.
Andy
Andy
