Sorry paul,
i explain bad, i not need a delay, i need, the effect holding pressed the on/off button to turn off.
The time of holding pressed 5-7 seconds.
How i can regulate the time holding pressed button? changing the capacitor?
i do that athis schematic with 4130, but i havent got , the effect to holding pressed button to turn off only
in that diagram if i chgange the relay for a p mosfet, if i disconected the power supply,
how i can reset the memory of the mosfet with 5-7 after disconected?
thnaks for your help.
