Author Topic: Choice of Actuators  (Read 725 times)
Offline jots123Topic starter
  • Country: sg
Choice of Actuators
« on: December 31, 2019, 12:29:51 pm »
Hi all,
Does anyone have any recommendations for an positional feedback linear actuator with an inbuilt potentiometer that is strong enough to lift and support a person (max weight 80kg) on a chair with sufficient factor of safety? (Max load should be about 150kg) Basically, this electrical actuator is to replace the common gas cylinder in height adjustable chairs.
I have found some that might work but I have some problems with it..
The PA-17 Heavy Duty Actuator by Progressive Automations is capable of lifting very high loads (up to 900kg). However, it draws alot of current (20A @ 12V) and it is very expensive.. https://cdn.shopify.com/s/files/1/0061/7735/7891/files/Heavy_Duty_Linear_Actuators_PA-17.pdf?13226
Another actuator is the Feedback Rod Linear Actuators by Firgelli Automations which is much cheaper and draws less current (5A @ 12V). However, its max load is only 90kg, which just barely meets the requirement. https://www.firgelliauto.com/collections/feedback-actuators/products/feedback-rod-actuator
I also need the actuator to have a minimum stroke of 13cm (5.2 inches). I have been searching for a suitable one for days. :( Any recommendations and suggestions will be greatly appreciated! Thanks!
