Author Topic: Add a desoldering gun to the AOYUE Int968A+  (Read 1530 times)
Offline light767Topic starter
« on: April 29, 2019, 10:22:54 pm »
Hi there!
I'm an hobbist electronic guy and I would like to buy one of this chinese soldering station all in 1, I really know that are the best of quality like Hakko o some other best brand but I really do use it time to time so I would like to give them a chance.
I have seen this AOYUE Int968A+ https://www.aoyue.eu/aoyue-int968a-repairing-station-hot-air-soldering-station-3in1-with-tweezer.html that just have everything expect the desoldering gun so my question is, is that possible to attach the desoldering gun to the vacuum inlet that is currently used for the smoke adsorber?
Offline kronk
Re: Add a desoldering gun to the AOYUE Int968A+
« Reply #1 on: August 15, 2020, 03:11:48 pm »
I know this is old but one of the only two threads that exist on this topic. the other is here:
https://www.eevblog.com/forum/beginners/help-desoldering-through-hole-components-with-an-aoyue-968a/msg487784/#msg487784
Thought I would keep from clogging google with another thread and just piggyback here.
I found this post and the other because I have the 968A+ and I have made a simple modification to attach a desoldering gun to it. The short answer is that with a jumper wire between pin 6 and the back of the "smoke absorber" vacuum switch (or 2 other places depending on how tidy you want it) you can make this work as though it was always meant to do it! You'll also need to make sure of the wiring of the desoldering gun and may need to replace the connector it comes with like I did.
I recently began a significant salvage effort on a pile of old electronics. The solder sucker was just not cutting it not to mention my hands were starting to hurt and I hadn't even finished one board. I don't need/want yet another box on my bench and I had the same thought as you - this thing has a very strong vacuum in it already, can't I just use a desoldering gun for it?
The Aoyue desoldering gun has been discontinued, so I looked for other options on the Amazon etc. I landed on the one below but it is 8pin so I also ordered a few GX-16 6 pin connectors to fit the 968A+. I had checked the specs of the station it is compatible with and it is 75W so I figured it was safe for the 70W of the Aoyue. I cracked it open to figure out what wires did what, drew a simple pinout, then wired up the new connector.
https://www.amazon.com/gp/product/B07Z76P231/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Simple trace tracking showed me what connects to the switch, which pulls low to tell to controller to turn on the pump. Therefore, the switch can share ground with the thermocouple. Thus the jumper from pin 6 to the vacuum switch and the switch at the gun handle connects pin 6 to controller gnd.
Plug it in and voila, works beautiful. Happy to put up pics or help anyone interested in doing this.
The following users thanked this post: mindcrime, frgmnt
Offline frgmnt
« Reply #2 on: August 04, 2022, 09:59:11 am »
Hi kronk!
 Thank you for this post. I will also try it.
It´s almost two years, can you still post some pictures? I am not 100% sure which pin is #6.
Offline Rotatceps
« Reply #3 on: November 24, 2023, 11:11:04 am »
This thread helped me, so attached some pictures for anyone who is also looking to adapt the YIHUA#948G themselves.
The GX-16 6-pin is labeled on the connector but I've numbered them in my drawing (male end). As follows:
1: Heating Element (White)
2: Heating Element (Yellow)
3: Ground (Green)
4: Thermocouple (Red)
5: Thermocouple (Blue)
6: Unused
Can't guarantee the colors will match what's connected in the gun so definitely check. I melted the thermocouple wire on my first go, connecting it to the heating element power.
I could've re-used the black wire coming from the switch but I cut it out thinking I just wouldn't use the switch.
Ended up running 2 new wires from the switch to some leads from inside the station, those are connected to the smoke absorber switch.
« Last Edit: November 24, 2023, 11:17:29 am by Rotatceps »
