Author Topic: op amps ... again?  (Read 4142 times)
Offline ilbsTopic starter
op amps ... again?
« on: October 06, 2013, 11:48:59 pm »
Hello,
I thought I had it down packed, but no, this combination of voltages doesn't work with any of the 4 calculative attempts  :palm:
Its an op amp with a 9vdc to 12Vdc ramp at its inverting input and a steady 5 Vdc at its non inverting input. The output was selected as going from 5.5 down to 3.5 Vdc.
In my last post, a fellow warned me to try several values for the gain and I tried doing so and which have always resulted in weird anomalies like the one shown in
attachment ...  :-//
Once I even got a -1.5Vdc as Vgnd... which would be impossible to attain with the value of V2 shown in the attachment!   :-\
I tried gains like 2.0, 0.5 ect...
So confused!
Can anyone help please   :palm:
« Last Edit: October 06, 2013, 11:54:19 pm by ilbs »
Offline c4757p
  • adieu
Re: op amps ... again?
« Reply #1 on: October 06, 2013, 11:53:11 pm »
Simple... 5V isn't enough. The virtual ground point is going to be somewhere between the input and output ranges. Right in the middle of 9-12V and 5.5-3.5V is around 7V.
« Reply #2 on: October 07, 2013, 01:31:42 am »
Posted by: c4757p
« on: Today at 10:53:11 AM » Insert Quote
okay.... if you say so!!! I will take your word for it.
So there are certain situations that are not doable !!
thanks
« Last Edit: October 07, 2013, 01:38:57 am by ilbs »
Offline c4757p
  • adieu
« Reply #3 on: October 07, 2013, 01:42:41 am »
Easy enough to imagine for yourself . You can feed 5V into a 5000 gain amplifier all you want - you're not getting 25 kilovolts. If you don't have it you can't get it - and the same applies for trying to get 7V out of a voltage divider when you've only put in 5V.
If the power supply rails are stable enough, just use them. Assuming they're close to +-12V or +-15V, you should have plenty of voltage there to pick off whatever you want with a voltage divider.
Offline w2aew
    • My YouTube Channel
« Reply #4 on: October 07, 2013, 02:32:45 am »
Ok, so you want a convert a ramp that goes from 9 to 12v into a ramp that goes from 5.5v down to 3.5v, right?
You're taking a 3v swing and dropping to a 2v swing, and you're inverting, so you want a gain of negative 2/3rds. So, something like 2.2k from output to inverting input, and 3.3k from inverting input to the 9-12v ramp. Be careful of your choice for op amp, some might not be stable with a gain of less than unity.
Now, some simple algebra says that the voltage at the non-inverting input that gives you the output swing you want is 6.9v. So, make a resistor divider between your 5v input and some convenient voltage source (positive supply rail?) to give yourself a 6.9vdc input on the non-inverting input.
Done.
FAE for Tektronix
Offline c4757p
  • adieu
« Reply #5 on: October 07, 2013, 02:37:19 am »
Or just scrap the 5V input and do it between V+ and ground!
Offline w2aew
« Reply #6 on: October 07, 2013, 02:43:18 am »
I was assuming that the OP had a particular reason for needing the +5v as the other input...
FAE for Tektronix
« Reply #7 on: October 07, 2013, 02:52:00 am »
okay okay I got it guys..... I see the dilemma  :)
I'm just experimenting with values and I realize now that
at best Vra can be 3.5Vdc making my inv input 5.5Vdc....
and therefore I can't squeeze more lemon juice
out o a dried out lemon.... the lemon being the 5vdc....
so okay I got it thanks for your hep  :-+ :-+
Offline c4757p
  • adieu
« Reply #8 on: October 07, 2013, 02:54:16 am »
Maybe you could squeeze your extra 2V out of the lemon...
« Reply #9 on: October 07, 2013, 03:25:59 am »
 ;D :clap:
Offline w2aew
« Reply #10 on: October 07, 2013, 03:36:18 am »
Hmm, ok.  My suggestion didn't suit your needs? Worked on my bench...
https://www.eevblog.com/forum/beginners/op-amps-again/msg303228/#msg303228
FAE for Tektronix
