Author Topic: MAX4460 inst. amplifier - maximum differential input voltage difference?  (Read 761 times)
Offline PtzfTopic starter
  • Country: ee
Hello!
I have a hall effect current sensor that outputs 185 mA per Ampere. The quiescent voltage is 2.5 V at 0 A, the current sense signal is summed op top of that. My ADC unfortunately demands a maximum of 2 volts at the input (0-2V that is). Now, my solution would be to use a differential amplifier to subtract 2.5 volts at the inverting input and set the gain to around 3.5 (3 A max input, thus (0.185×3)×3.5=1.94 V).
I went for a simple solution (I can be corrected here) and tried out a MAX4460 instrumentation amplifier to achieve the desired goal. I set the gain with R2=68k and R1=33k, as specified in the datasheet. I fed the inverting input a steady 2.5 VDC from a power supply. The non-inverting input signal was also fed from a power supply. The following behavior was present with or without a load resistor at the output. Inst. amp supply voltage was 5 V.
What I discovered was that the output of the inst. amp. was very nicely around 0.00V at non-iverting inputs below 2.5 V. As soon as the input went above 2.5V, I saw a nonzero output. What puzzled me, however, was that as soon as I reached an non-inverting input of 2.94 V, the output latched to 5V (the difference between the input ports at this point was 400 mV). A few millivolts below and the output went back to around the expected ~1,3 V.
The datasheet says that this inst. amp is meant to amplify small diferential signals, and even specifies some ranges for other models than the MAX4460.
My question: Is this latching behavior at "large input" voltage differences a "real life" property of opamps (inst. amps in specific)? I'm a opamp newb, so I have the feeling that I'm missing something. Or in general - whats up with this latching?
Offline Wimberleytech
Re: MAX4460 inst. amplifier - maximum differential input voltage difference?
« Reply #1 on: December 04, 2018, 06:44:52 pm »
No.  Generally it is not a "real life" property of opamps.
Not sure what's up with the latching.
Their input structure may be this: US6559720
https://patentimages.storage.googleapis.com/92/22/18/3f127117f41ba2/US6559720.pdf
« Last Edit: December 04, 2018, 06:48:15 pm by Wimberleytech »
