Author Topic: switching/routing data signals only ddoable with relays?  (Read 833 times)
Offline somuchtylerTopic starter
« on: December 04, 2018, 10:38:30 pm »
Lets say I am working on a project that requires me to switch between 5 different headphone jack sources to one headphone. The only way to accomplish this is to use a set of two relays per source and design my project to power on the set of relays of the source that i want to listen to?
My question is, is this only achievable through relays? Is there a less expensive option?
Offline Wimberleytech
Re: switching/routing data signals only ddoable with relays?
« Reply #1 on: December 04, 2018, 10:54:09 pm »
There are many ways to do this. Take a look at MAX4908.  Maybe use two of them?  You could roll your own with FETs/analog mux circuits.
Offline Paul Moir
« Reply #2 on: December 05, 2018, 12:16:32 am »
Can or do the sources share a common ground?  That's really going to drive the design.
