Author Topic: Need Help Identifying '45A 9081' Marked TSSOP EEPROM  (Read 2843 times)
Offline MechatrommerTopic starter
  • Country: my
  • reassessing directives...
« on: October 17, 2013, 01:56:15 pm »
probably TSSOP, cant measure too small and congested. its serial EEPROM thats affirmative from the service manual (named only as IC7 :'() google returns unexpected results.
btw: its my canon flash 550EX unit thats giving faulty flash power output (full discharge at minimum 1/128 power setting). there are many areas to suspect, one of it is, faulty or erased EEPROM content, is it possible after about 5 years of service? thanks.
« Last Edit: October 17, 2013, 01:57:57 pm by Mechatrommer »
Offline amyk
Re: Need Help Identifying '45A 9081' Marked TSSOP EEPROM
« Reply #1 on: October 18, 2013, 11:59:03 am »
I've seen this part number (9081) before somewhere... although I can't remember exactly where
Part number suggests Rohm (they have a BR9080 but it's a different interface) - the AK6440BH and the like have the same "SCI bus" interface (something like SPI but a Japanese variant) so maybe you could figure out the rest from there. Put a logic analyser on the signals and see what you get.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: October 18, 2013, 12:27:34 pm »
Pinout looks like fairly standard 93xx SPI style - probably worth trying to read as one of those.
Day Job: Mostly LEDs
Offline fluxcapacitor
« Reply #3 on: October 18, 2013, 05:03:33 pm »
My guess its a  ASAHI KASEI AK93C45A
Offline amyk
« Reply #4 on: October 19, 2013, 08:30:10 am »
Doesn't have a RESET pin.
If the OP is looking at the same schematic as I am, this particular EEPROM has a pinout like this:
1|/CS   VCC|8
2|/SK    NC|7
3|DI  RESET|6
4|DO    GND|5
« Reply #5 on: October 19, 2013, 12:41:03 pm »
1|/CS   VCC|8
2|/SK    NC|7
3|DI  RESET|6
4|DO    GND|5
But pin 6 and 7 aren`t connected ? I couldn`t find the schematic ,the only one i could find was for the 580EX ,i assumed wrongly that it would have a similar layout and eprom .I did look at the pinouts on plenty of datasheets but on all of them pins 5-8 were different. Any chance you can upload your schematic .
My mistake amyk ,i didnt read your answer correctly .I found the 550EX schematic though.
« Last Edit: October 19, 2013, 11:24:35 pm by fluxcapacitor »
Offline amyk
« Reply #6 on: October 20, 2013, 05:50:26 am »
Oops... looks like we both made the same mistake - I assumed the 580EX would have the same EEPROM. But RESET pin is tied to ground so not used anyway.
In that case, I'd agree with 93Cxx.
