Author Topic: Circuit to lower Sine wave frequency  (Read 2164 times)
Offline AlfganTopic starter
  • Country: lt
« on: October 31, 2019, 08:14:18 pm »
Hello everyone!
I have a question. Is there a circuit or component or chip that lowers sine wave frequency?
For example I wave a supply of 100Hz 20V sine wave and I need 40Hz 20V sine wave... what circuit or component would make it possible?
Thanks
Have a good day!
Offline jhpadjustable
  • Salt 'n' pepper beard
Re: Circuit to lower Sine wave frequency
« Reply #1 on: October 31, 2019, 09:31:06 pm »
For what purpose?
"There are more things in heaven and earth, Arduino, than are dreamt of in your philosophy."
The following users thanked this post: Alfgan
Offline ogden
  • Country: lv
« Reply #2 on: October 31, 2019, 09:43:46 pm »
System containing rectifier + inverter would do the job. Not trivial "circuit" at all.
  • Country: lt
« Reply #3 on: November 01, 2019, 09:08:36 am »
I was only interested if it is possible.
Offline ratatax
« Reply #4 on: November 01, 2019, 10:17:07 am »
An approximation could be to saturate the sine wave to make it square, then use a flip-flop to divide its frequency by 2 and smooth it to make it look sine again (will probably be a bit dirty though, and it's for signals, not power)
Offline Twoflower
« Reply #5 on: November 01, 2019, 10:22:49 am »
Depending on the requirements (power, stability, ...) a motor-generator system would be an option. But with the little information it's not easy to provide a viable solution.
Offline mikerj
« Reply #6 on: November 01, 2019, 01:53:52 pm »
That would get you 50Hz rather than 40Hz.
Assuming this is to provide power to something then converting the DC and generating a 40HZ AC is likely the only practical way of doing this.  If these were high impedance signals then you could use a mixer along with a fixed 140Hz signal to downconvert the 100Hz to 40Hz, or you could do it with a PLL and fractional N divider.
« Last Edit: November 01, 2019, 03:56:24 pm by mikerj »
Online rstofer
« Reply #7 on: November 01, 2019, 03:49:46 pm »
Without knowing the load, it isn't even possible to suggest a solution.  It might be fairly easy to do this kind of thing with a phase-locked-loop, at signal levels, and it might be easy to do with a motor-generator, at power levels.  The recitifer-inverter solutions might be fine for power levels.
There is a world of difference between the solutions.
Offline grifftech
    • youtube channel
« Reply #8 on: November 01, 2019, 05:37:53 pm »
rectifier, amplifier, MP3 player
Offline KMoffett
« Reply #9 on: November 01, 2019, 05:55:16 pm »
Just a thought design:
Phase lock loop to multiply 100Hz x 4 for 400Hz. Follow with a digital divide-by-10 for a 40Hz square wave. Through a very narrow 40Hz bandpass filter. Then amplify to need level.
Offline Audioguru again
« Reply #10 on: November 01, 2019, 06:05:16 pm »
Many people use a switched capacitor multiple order lowpass filter IC to convert a squarewave to a pretty good sinewave.
Online Kleinstein
« Reply #11 on: November 01, 2019, 07:55:59 pm »
One could first set up the frequency (e.g. a via PLL or nonlinear multiplier) and than use that clock to generate a sine from a look up table or the like.
Chances are the amplitude information would get lost.
Another option would be a mixer (or 2) to shift the frequency by a constant amount.
Online rstofer
« Reply #12 on: November 01, 2019, 08:48:12 pm »
We still don't have an answer to milliwatts of megawatts.
Offline Le_Bassiste
« Reply #13 on: November 01, 2019, 09:27:14 pm »
Hello everyone!
Thanks
Have a good day!
these circuits are commercially available as "variable frequency drives" for basically all powers from kW to MW.  if you just need a couple of watts, you could use your hifi amplifier. the basic principle is always the same
1. take what you have and rectify / filter it to DC
2. take the DC and power a halfbridge/fullbridge with it
3. control the output of the bridge by applying a control signal of your choice (waveform, frequency, amplitude).
OTOH,
if you want to consistently change input frequencies (that is, 100 Hz to 40 Hz, 500 Hz to 300 Hz and so on)  you could feed the (heavily attenuated) input signal into a device that is called a "harmonizer", something like the old "Ibanez HD1000", or the famous Eventide harmonizers. and then feed it into an amplifier to boost it back to the desired level.
An assertion ending with a question mark is a brain fart.
Offline IconicPCB
« Reply #14 on: November 02, 2019, 07:43:15 am »
Google Cycloconverter
Online soldar
« Reply #15 on: November 02, 2019, 10:03:27 am »
Not only that but it needs to be clarified whether he is just trying to get 40 Hz or whether the 40 Hz needs to be in sync with the original frequency. Because they are radically different problems.
Offline Zero999
  • 0999
« Reply #16 on: November 02, 2019, 02:28:03 pm »
Use a fullwave rectifier to get 200Hz, divide it by 5 to get a 5Hz squarewave and pass it through a low pass filter to convert it to a sine wave.
Offline SparkyFX
« Reply #17 on: November 03, 2019, 03:40:50 am »
Getting a 40Hz in sync with 100Hz is unfeasible, unless it needs to start synced or so, but then its just as good as  triggering a second source.
Support your local planet.
Offline bob91343
« Reply #18 on: November 03, 2019, 06:11:14 am »
Use an electronic piano keyboard.  The lowest E (on a full keyboard) is close to 40 Hz.
Offline jeroen79
« Reply #19 on: November 03, 2019, 03:32:27 pm »
Then the answer is "Yes".
But if that is all you want to know and you have no actual application for this then there is little use in coming up with an actual "circuit to lower a sine wave frequency".
« Last Edit: November 03, 2019, 03:36:18 pm by jeroen79 »
