Author Topic: Alternative to FFC board to board interconnect.  (Read 2874 times)
Offline JacksterTopic starter
    • PCBA.UK
« on: June 12, 2017, 10:21:38 am »
Hi all.
So currently I am using FFC cables to connect 3 boards together. The main problem is is that these are really hard to mount onto the board as I am soldering these all myself.
The room is so small on my boards that I am having to use 1mm cable which results in 0.5mm pin pitch on my circuit boards.
I am getting some boards made but yields are low.
What are my other options for board to board interconnect when you have very little room, not able to use hard connectors like pin headers etc?
Thanks
Jack,
Offline ManCave
Re: Alternative to FFC board to board interconnect.
« Reply #1 on: June 12, 2017, 10:38:57 am »
you could design the three boards with built-in interconnection to each other on a rigid-flex PCB like this:
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: June 12, 2017, 11:08:15 am »
Hi all.
Thanks
Jack,
Are you soldering the cables or the connectors?
If the former then you are doing it wrong.
And ho
w do 1mm cables result in 0.5mm pitch?
Day Job: Mostly LEDs
    • PCBA.UK
« Reply #3 on: June 14, 2017, 07:22:16 am »
Wayyy above my skill level with PCB design.
Looks awesome though!
And ho
Conector. Sorry the pitch is 1mm but the pins are 0.5 from the looks of it?
