If you mean PST518B, that is not a transistor, it is a reset controller. It can assert the reset line when the +5 V rail is below about 4.4 V. Because of the open-collector output, which is wired-or connected to the '339 open-collector output, you can actually just leave the component out. The rest of the reset circuit will function just like the old version without this.
