Author Topic: Cleaning sugary drink from a board  (Read 6694 times)
Offline ZithenTopic starter
« on: May 05, 2014, 12:45:46 am »
I had seen some posts on cleaning boards with 91% (or so) isopropyl Alcohol and a few other things, but didn't know if that might be a good way to clean off dried up sugary drink?
I had gotten a arcade board and it looks like someone dumped a their cup of pepsi all over it and then it just sat there. I didn't know if using alcohol would be good to clean that out and if so do you just dump some on it brush it with a soft toothbrush then let it dry?
Watched several youtube videos on cleaning and they seemed to range in different ways, but didn't really know if what I was watching would be a good way or just what someone thought would be a good way. Any advice would be great.
Thanks
Online Lightages
  • Canadian po
Re: Cleaning sugary drink from a board
« Reply #1 on: May 05, 2014, 01:03:51 am »
A big tank of distilled or deionized water. Let it sit for a day, change the water, day, change, day change. Give it a good scrub with a non-static brush and cleaning mix of 10 parts water, 1 part isopropanol, and a bit of dish detergent. Then back into the water bath a couple of more times. Then a good rinse with pure isopropanol. Let it dry completely before powering it up.
Offline KD0RC
« Reply #2 on: May 05, 2014, 01:34:08 am »
One thing to look for after you have the crud cleaned off it is whether the acids in the drink ate any of the traces, component leads and that kind of thing.  Use a good magnifying glass to spot problems before powering it up.  This will give you a chance to reeconnect things if needed.  Pepsi, Coke and other products often have phosphoric acid in them which, over time, can really wreak havoc...
« Reply #3 on: May 05, 2014, 02:21:14 am »
with soaking it do I need to worry about the removable eproms? I am guessing know, but just don't know if the little glass window is water proof or not.
That is one thing I hope hasn't done to much damage and hoping for no damage. If it has the good side it was free, the bad side is that its Teenage Mutant Ninja Turtles. That game was fun  ;D
Online Lightages
  • Canadian po
« Reply #4 on: May 05, 2014, 05:18:21 am »
It should go without saying that you should remove all socketed components first.
Offline G7PSK
  • It is hot until proved not.
« Reply #5 on: May 05, 2014, 08:33:40 am »
I  just wash boards in the kitchen sink using tap warm water and detergent then shake off excess water and rinse immediately in alchohol and dry in warm air either the airing cupboard or a hair dryer depending on how fast I want the board.
Offline rdl
« Reply #6 on: May 05, 2014, 02:17:26 pm »
I clean boards by just running them through the dishwasher. As soon as it's finished, pull the board out and rinse with distilled water. Allow to air dry for about a week, then bake for a couple of hours at around 175F (around 80C).
« Reply #7 on: May 05, 2014, 03:16:23 pm »
I had thought as much, but just wanted to make sure.
Thanks for all the suggestions.
Offline rexxar
    • Forever Tinkering
« Reply #8 on: May 05, 2014, 04:52:36 pm »
That's kind of terrifying, actually  :o
« Reply #9 on: May 05, 2014, 05:48:57 pm »
Not really, a lot of PCB assembly houses use a regular dishwasher to get flux residue off the boards. they just use a warm oven as well afterwards to get the last of the water out.
Offline Little Brutus
« Reply #10 on: May 05, 2014, 09:37:19 pm »
I've used the technique to clean computer keyboards... especially older IBM clicky board with the removable key caps (those sucker are actually pretty hard to kill)
rules
#1: Don't use soap
#2: Don't use the dry cycle
#3: Make sure you let it completely dry
#4: hard way, if removing the key caps, put them in a cheese cloth bag and not just the cutlery thing. They get everywhere <G>
Offline Teledog
« Reply #11 on: May 05, 2014, 11:24:59 pm »
Had a "friend?" spill a "screwdriver"  into my Korg Trident ( showing my age?)
A  real PITA, but washed it out with water, then a rinse with distilled water..carefully (not fun)..use a lab wash bottle..
Offline envisionelec
« Reply #12 on: May 05, 2014, 11:26:43 pm »
Distilled or Deionized water.
I've used tap water in an emergency: my wife's laptop got drenched by a sugary drink. I immediately popped the battery out, ran to the sink and turned the tap on full blast letting water run out the cooling louvers. I shook most of the water out then let it sit in the window to get some warm sun (it was winter...no going outside in Ohio). Waited ONE DAY and powered it up. Not even a hiccup. ;)
YMMV.
Offline TheGenesis
« Reply #13 on: May 05, 2014, 11:44:46 pm »
Coke ... sugar ... food ... and already dried-up ... this little helper removes anything:
http://de.farnell.com/kontakt-chemie/kontakt-lr-400-ml/leiterplattenreiniger-400ml/dp/3047453
Offline JoeyP
« Reply #14 on: May 06, 2014, 01:50:35 am »
I've seen commercial contract manufacturers who routinely clean all of their production PCBs this way. Works quite well actually. They'll use purified water for it, but you can get away with using normal tap water as long as you rinse with clean water before they dry.
I've also heard of people using "Jet-dry" in the dishwasher to prevent mineral deposits from tap water. The tradeoff is that it coats them with a thin layer of silicon, which makes them hell to solder after (so don't clean until all hand-soldering is completed). The silicon can be cleaned off with Acetone if needed for rework after washing.
Offline electrolux
    • Photography
« Reply #15 on: May 06, 2014, 08:57:33 am »
Put under water indstead ^-^
The funniest thing about this signature is that by the time you realize it doesn't say anything its too late to stop reading it.
« Reply #16 on: May 06, 2014, 06:57:29 pm »
Just took the board out from the first day of soak. That was nastiest thing I have seen in a while.
It's looking good so far. The parts that have cleaned up so far don't look to bad. Hopefully after another soak the more covered section will clear up and be able to see what damage was caused by the soda.
Offline Rigby
  • Learning, very new at this. Righteous Asshole, too
« Reply #17 on: May 08, 2014, 02:52:44 am »
Pictures?
Offline BurningTantalum
« Reply #18 on: May 08, 2014, 10:23:56 am »
I will second the 'warm water and detergent' procedure- For many decades I augmented my pay by repairing CRT TVs, going way back to Philips G8s etc. I always cleaned the crud and nicotine from the PCB with hot water and Fairy liquid using a soft paintbrush, followed by a de-ion water rinse and a week to dry above a heating radiator, or later a dehumidifier. I must have done many dozens like this and never a problem with the EHT etc. Not too many worries about ESD in those days, but I have done this recently to clear tea from a Dell laptop, and mud in a HDD recorder and have not had a problem.
Regards, BT
Offline madshaman
  • ego trans insani
« Reply #19 on: May 08, 2014, 01:49:46 pm »
There's a pretty good chance the pop's carbonic acid (CO2 in solution) had a chance to do some eating.
To be responsible, but never to let fear stop the imagination.
« Reply #20 on: May 09, 2014, 03:15:43 pm »
Pictures?
I am a terrible person because I didn't take any pictures. I was actually thinking about that when I was doing a final cleaning of the board early this morning.  |O
I don't think the drink was on there as long as I was told or the board was amazingly durable. It was dried on there pretty good, but after the first soak and brushing it come off pretty good with some areas still bad. After another soak and brushing there wasn't really anything left. After another short soak and cleanup you really can't tell anything was on it expect a few sticky spots on the top of the eproms.
Right now it's drying and hopefully later tonight or tomorrow morning will boot it up and see if it works.
There is only one place that looks like it might be a problem and that is between two pins of a chip it looks like the they expanded or something and cracked a little bit of the board. The bad thing is there is two traces that go through that spot. Once it dries that is the first thing I need to check. Other then that you can't even tell it had something on it.
Offline Rigby
« Reply #21 on: May 09, 2014, 03:22:07 pm »
well the stuff that is left when soda dries up is still the stuff that's designed to be water soluble.  It shouldn't be a big deal to remove.
you can tell the age, usually, by the amount of dust that is stuck to the syrup.  not a lot of dust = not a lot of time.
« Reply #22 on: May 10, 2014, 01:49:07 am »
Looked the board over and only just that one spot that looks bad. Tested the pins next to the area and the two traces that go through that spot and seems ok according to the continuity. Turned the game on the game actually works...kind of. The only issue is that there is some audio issues, mainly with the voice audio. Just so happens that chip is in the voice diagram.
Haven't worked on a board issue like this, but just mean time to learn new stuff  ;D
« Reply #23 on: May 10, 2014, 05:34:57 am »
Time to unsolder that chip and clean up and repair the 2-5 through hole vias under it that are now high resistance. When you have the chip out place a 28 pin turned socket in there, and put the chip into another 28 pin turned socket so you can remove it later if needed.
« Reply #24 on: May 11, 2014, 04:59:54 pm »
I was wondering what you would do to repair the through hole vias (sorry just a bit new to board work).  The cracking or what not that is there between the pins seems to be only on the top layer. There is nothing showing through on the bottom side.
