Electronics => Beginners => Topic started by: masibp on October 01, 2013, 08:55:43 pm
Hello friends. I am being told that the water tank has a capacity of 100cm level. The desired level is 80cm. How should I calculate the control valve constant (Kv)? Q(s)=KvP(s). Q(s) is the inflow rate, P(s) is the pressure driven into the control valve Kv.
Beats me!
Could you elaborate? :D Just too much missing information!
In fact if you reread, this question makes zero sense.
id read the right books
they are hundreds of control loop theory
