From that circuit, if the delta R = 0 and the other resistor pairs are exactly equal, then the output voltage will be zero.
If you then add a delta R, simple algebra gives you the non-zero output voltage.
The ratio of that voltage to the input voltage (at the bottom of the drawing) gives you the CMRR.
