Author Topic: Iphone 5S schematic  (Read 3825 times)
Offline JaneTopic starter
Iphone 5S schematic
« on: September 03, 2016, 08:17:35 am »
I downloaded Iphone 5S schematic. I would like to learn how to read those schematic but do not understand what those small numbers( I put them into a  red rectangle) mean.
Can anyone please let explain what those numbers ( marked  in red rectangle) mean?Thank you
Offline tautech
Re: Iphone 5S schematic
« Reply #1 on: September 03, 2016, 08:22:56 am »
Bus or Net #'s ?
Are they duplicated elsewhere in the schematic?
Offline Rerouter
« Reply #2 on: September 03, 2016, 08:28:20 am »
If i recall, they are the page numbers those nets also connect at.
« Reply #3 on: September 03, 2016, 11:53:06 am »
I also thought it was a page number but , when checking, it did not make sense.
The complete schematic is at
https://www.ulozto.net/!QajKT3HZu/iphone-5s-820-3292-a-zip#_ga=1.1862388.498748459.1472901950
Any idea what the numbers mean?
Thank you
Offline amyk
« Reply #4 on: September 04, 2016, 12:50:32 am »
Definitely page numbers. If the schematic has been edited by someone else, they might not match up exactly but you should look for "sheet # x of y" or similar in the corner to find the corresponding page. You'll see these a lot if you look at laptop schematics too.
