Electronics => Beginners => Topic started by: Strand17 on March 31, 2021, 08:15:31 pm
I need help identifying a type of cable.
Some laptop power supplies use a coax cable with large conductor cross-section on the DC side. What is the proper designation for this kind of cable? I have tried searching at both Mouser and DigiKey, but without luck. I must be missing the right search terms...
Are there triaxial cables of this kind available too?
Any help would be very appreciated!
Jonas
UL style 10846 cables are used in laptop power supplies
https://www.digikey.com/products/en/cables-wires/single-conductor-cables-hook-up-wire/474?k=UL+10846 (https://www.digikey.com/products/en/cables-wires/single-conductor-cables-hook-up-wire/474?k=UL+10846)
Confusion reigns. First, power supplies seldom use coaxial cable. They might use shielded cable for rejection of radiated interference. Second, the link above goes to hookup wire, not coaxial or shielded.
The only concerns are that the wire is of sufficent gauge to carry the current, and sufficient insulation to stand off the voltage. Plus, environment is important as well.
Link is correct, UL 10846 is shielded hookup wire.
No, it is not the main reason. This coaxial construction allows to build compact cable with good flexibility in any direction.
Coaxial cable, or coax (pronounced /ˈkoʊ.æks/) is a type of electrical cable consisting of an inner conductor surrounded by a concentric conducting shield, with the two separated by a dielectric (insulating material); many coaxial cables also have a protective outer sheath or jacket. The term "coaxial" refers to the inner conductor and the outer shield sharing a geometric axis.
Coaxial or co-axial is simply a description of the cable construction, and most laptop power adapters do in fact use a co-axial cable, which may not be the same as a shielded cable, that might be dependent on the nature of the shielding conductor, as with a laptop power adapter, the "shield" is required to handle the current drawn by the laptop, which can range from 2~3 amps to as much as 12~15 amps.
Cables with a third conductor do exist, Dell AC adapters in particular have a "data circuit" in addition to the two power carrying conductors - the laptops can determine the "wattage" of the adapter and will disable the battery charger if the AC adapter is a lower than required wattage, or it cannot identify the adapter.
Also - possibly worth a mention - all new residential AC utility power installations where I live are being run over co-axial cable by the utility company. Older installations are being retrofitted with the same co-axial drops.
To be precise, coaxial means sharing the same axis. In other words, some effort is made to make the center conductor actually in the center. Otherwise its high frequency integrity is compromised and it's just shielded cable.
It's a bit more expensive than hookup wire and so only gets used when necessary for noise rejection or compactness of cable.
I think you mean a shielded cable rather than COAX. Coaxial cables are for RF not power. The shield is to keep the PSU noise from leaking out. Poorly in most cases! You can buy triax but you'd be wasting your hard-earned cash. It's a very esoteric cable used in studio digital video and nano volt measurements.
There are a plethora of shielded multicore multi pair cables you can buy.
https://www.google.co.uk/search?q=shielded+multicore&source=lnms&tbm=isch&sa=X&ved=2ahUKEwiCqImV8d_vAhXa8LsIHT1fDzEQ_AUoAnoECAEQBA&biw=1825&bih=1010 (https://www.google.co.uk/search?q=shielded+multicore&source=lnms&tbm=isch&sa=X&ved=2ahUKEwiCqImV8d_vAhXa8LsIHT1fDzEQ_AUoAnoECAEQBA&biw=1825&bih=1010)
(https://images-na.ssl-images-amazon.com/images/I/512rrtb-QZL._AC_SY355_.jpg)
UL1185? If you have the cable in question, did you check the text on the cable to see if there was some UL style number?
More of a spiral wrap than coaxial. I think the main point of this style of cable is to maximize conductor cross section for a given outer diameter. The spiral-wrap may also have some EMI advantage compared to parallel pair.
You are ripple on my rail son.
