I am an intermediate beginner in electronics and brand new to digital scopes. I have the Hantek DSO5102P
I noticed that when I hook the scope to the signal generator and pump in 10V at 1.7 KHz (sine wave) that the scope's onboard frequency counter loses accuracy when I lower the Volts/Div from 5v/div past 500mv/div . That is to say, that the last division the Hantek's onboard scope is accurate is at 500mv. When I go below that to 200mV, 100mV, 50mV, 20mV, and 10mV the frequency counter becomes way off.
However, when I view the Hantek's measured frequency it is spot on.
What gives?
Addendum: I lowered the Voltage out from the function generator to 1V and raised the frequency to 1MHz. Now the onboard frequency counter works all the way down to 10mV/Div with absolutely no problem.
What I don't understand is that the V/Div is only a "monitoring" function, yet when I change it it seems to affect the onboard frequency counter which, to my mind, should not be affected at all. Anyone know what's happening here ? I noticed the same effect on my analog scope as well.
Alan
