Hi David, thanks for the reply.
I see your point but the draw from the device itself as well as the circuit shown above (bearing in mind the device will be in a low power sleep mode if it's left unattended) will be maybe 50 microamps. I don't think that would equate to much of a voltage drop from the battery but I could be wrong. All it's got to do is prevent power getting to VOUT if the battery level is below a threshold. That threshold doesn't have to be accurate or dead on, anything around 9V is fine. It's just to stop the battery getting too low that's all. Whatever it does at "around" the threshold level is pretty much unimportant. All I need to know is if the circuit will definitely prevent the battery draining to below 9V or there abouts. When you say the zener won't be accurate, is that because of the high resistances I'm using? Would it be significantly inaccurate?
I'm sorry but I had to do some Googling to understand what you meant by Hysteresis. I'm only a beginner. This is kind of an "overlap" like a schmitt trigger? Meaning if the battery drops below say 9V then a latch would trigger and prevent the circuit switching on again unless it rises to like 9.5V (just as an example)? If so then I really don't need it to be that complex.
Thanks you for the help, at least I learned what hysteresis was
I tried mucking around with some Schmitt Triggers in a couple of emulators but I just can't get them to work. I have only tried both basic op-amp types, I'll give the dual transistor version a go as well.
Cheers
Marcus.
EDIT: Actually no scratch the idea. I've just realised after you mentioned battery voltages recovering when the load is removed. When the device is actually in operation, it's drawing big current. It is very possible that normal usage with a mid-charged battery could cause a drop to below 9V which would cut the device's power. Making the device only usable with a battery that's fully charged or close to fully charged. So no this is a bust.
darn. I suppose I could have an NPN transistor on the fet gate to ground which is switched on by the main output of the device itself so that when the device is fired, the fet gate is pulled low so it can't turn off.
I'll try to explain what the device is and the protection I need a little better. The device is an e-cig, it sits around for most of the time doing nothing but monitoring the state of a fire button. When the fire button is pressed it powers the atomising element (a heater coil) which produces the vapour. The atomising element can be as low as 0.4 ohms or sometimes lower depending on the voltage it's driven with. It is possible that the device may be left unattended or unused for a few days, since it is "always on" monitoring for user input, it's a constant drain on the battery albeit very small. Should the battery fall to a very low voltage if it's left long enough, the LiPo cells get buggered and cannot be recharged (not without removing the pack and messing with it anyway). All I need is a circuit to prevent that from happening. I don;t need Mr Spock accuracy on the voltages involved.
This is a video of my previous attempt at this kind of thing. Although the one in this video is mains powered. Imagine the same thing but smaller and battery powered.
There's a tiny bit of bad language in the video.
