It's not about it being simple or not simple, it's about us understanding what you actually want, so we can make good suggestions, i.e., see what is the simplest way to achieve your goal, whatever it is.
For example, it was a bit unclear if the device needs to detect color of external objects, or color of external light. The former is easy to do using the method described by Zero999 and myself. If it's about the latter, then you need a sensor with color filters. Look at the parametric search of your favorite distributor; I haven't used color sensors myself lately but I'm sure you'll find some nice tiny integrated chip with color filters and R,G,B light sensors and their signal conditioning all nicely integrated.
What do you mean by "trigger"? You mean, like "red color detected" -> "play a certain sound"? This is all doable using analog electronics, but likely much easier to achieve with a microcontroller, so you can empirically adjust detection algorithms and thresholds. For example, certain "red" color might look quite red to your eye, but still cause a significant signal level on the green channel.
Finally, knowing your actual goal could help us give completely different suggestions. For example, if you are sorting LEDs with the contraption, then just measuring Vf at certain constant current (like 10mA) could prove easiest.
