Author Topic: Combining 4 Ohm & 8 Ohm speakers  (Read 3057 times)
Offline made2hackTopic starter
    • Made2Hack
« on: April 11, 2019, 05:26:40 pm »
Hi all,
I have this old pair of small shelf speakers that I want to freshen up. They have a 4 Ohm / 25 Watt mid range speaker. I am adding to it an 8 Ohm / 40 Watt tweeter. What would be the ideal way to connect the two since they are of different impedance?
I am using an off the shelf 3.3Khz / 12dB / octave RCL filter passive crossover.
Should I connect in parallel? Series? Any pros / cons? Or should I perhaps add a 4 Ohm resistor in series to the Mid range and then parallel the two speakers?
Thanks,
Offline grifftech
    • youtube channel
Re: Combining 4 Ohm & 8 Ohm speakers
« Reply #1 on: April 11, 2019, 06:26:27 pm »
just parallel them, the mid range speaker will take 2 times as much power as the tweeter.
Offline soldar
« Reply #2 on: April 11, 2019, 07:34:17 pm »
You might want to install a passive crossover filter
 https://en.wikipedia.org/wiki/Audio_crossover#Passive
Offline soldar
« Reply #3 on: April 11, 2019, 08:33:30 pm »
Oops. Sorry. My bad.
Offline Audioguru
« Reply #4 on: April 12, 2019, 01:50:22 am »
What impedance speakers is the crossover network made for? If it is for 4 ohm speakers then simply add an 8 ohm resistor parallel with the 8 ohm tweeter.
No woofer speaker?
Offline Zero999
  • 0999
« Reply #5 on: April 13, 2019, 06:02:29 pm »
Speakers don't have a flat, resistive 8 or 4 Ohm impedance at all frequencies. Does anyone know whether passive crossover networks are designed to take this into account? If so, then changing the speaker, will affect the frequency response.
I think you should try to stick to the same kind of speaker, both physically and mechanically to stand the highest chance of it giving good sound quality.
Offline Audioguru
« Reply #6 on: April 13, 2019, 06:27:24 pm »
Yes an impedance correction Zobel Network is used to flatten the inductive impedance of a woofer and flattens the resonant peak impedance of a tweeter.
    • Made2Hack
« Reply #7 on: April 14, 2019, 03:55:29 pm »
The crossover is for an 8Ohm load.
Thanks,
