Author Topic: What would happen if you connected 2 LiPo chargers (in parallel) to a LiPo batte  (Read 1541 times)
Offline monster_of_electronicsTopic starter
Anyone?  Would it charge twice as fast?
Offline Richard Crowley
  • KJ7YLK
NO. At best, it might charge slightly faster, but more likely at the "normal" speed.
At worst, overcharging the batteries can cause " overcharge, over-discharge, over-temperature, short circuit, crush and nail penetration may all result in a catastrophic failure, including the pouch rupturing, the electrolyte leaking, and fire."  --  FAA Battery Incident Chart, includes incidents of Lithium-Polymer-Air ignition after puncturing. Ex: Entry for 11-Dec-2007
Online T3sl4co1l
    • Seven Transistor Labs
Yes.  The initial constant-current phase will go twice as fast.  The CV phase will take as long; during that time, one charger may register as "done" while the other continues.
It's not recommended, for the reasons listed above.
Seven Transistor Labs, LLC
Offline lapm
Watch Daves video about lipo charging profile.. Watch it right now... There is very good reasons why charge is current limited...
Electronics, Linux, Programming, Science... im interested all of it...
