Author Topic: Bode plot of opamp integrator  (Read 622 times)
Offline opampsmokerTopic starter
« on: December 06, 2020, 04:53:34 pm »
Hi
Why does the LTspice AC simulation give the phase near the f=0 axis as 180degrees for this opamp integrator?
This cannot possibly be right. Surely?
The transfer function is – (1/jwC)/ R,
Which equals     0 + j (1/wCR)
The phase of this is atan {[1/wCR]/0}
..this is atan (infinite) which is n.pi/2, where n = +/- 1,3,5,7,9 etc
This cannot possibly be 180 degrees. Do you agree?
Offline mag_therm
Re: Bode plot of opamp integrator
« Reply #1 on: December 06, 2020, 05:23:01 pm »
It is an inverting integrator. (?)
Phase will go from 180 to 270 at the corner.
I use qucs and it is a bit tricky in graphing phase that goes through the upper/lower limits set by user on the phi graph.
But I think it does it correctly.
« Last Edit: December 06, 2020, 05:28:30 pm by mag_therm »
The following users thanked this post: opampsmoker
Offline Kleinstein
« Reply #2 on: December 06, 2020, 05:34:13 pm »
Near f = 0  Hz one would see the limited DC gain of the OP and thus a constant gain. So a 180 deg. phase is correct.
« Reply #3 on: December 07, 2020, 11:12:44 am »
Thanks, you mean if it was a ideal opamp then it would be 270 degs near the f=0 axis?
By the way, page 10 of the following has phase near f=0 axis as 90 degrees, not 180 degrees
ti.com application note
https://www.ti.com/lit/an/slva662/slva662.pdf?ts=1607167216358&ref_url=https%253A%252F%252Fwww.google.de%252F
« Last Edit: December 07, 2020, 11:15:10 am by opampsmoker »
