Author Topic: Comparator (LM393) not saturating at low frequencies  (Read 4289 times)
Offline floobydust
Re: Comparator (LM393) not saturating at low frequencies
« Reply #25 on: January 19, 2020, 12:15:44 am »
I've never seen a scope have an issue at low frequencies when DC coupled. It's a DC path from input to the deflection plates, really. So even that doesn't make sense here.
Online Gyro
« Reply #26 on: January 19, 2020, 10:53:33 am »
Read again. His AC/DC coupling switch was broken - didn't work in bypass the coupling cap in DC!
I don't know about the one on the channel next door though. I don't think he tried Ch2.
« Last Edit: January 19, 2020, 11:08:43 am by Gyro »
Best Regards, Chris
Offline nigelwright7557
    • Electronic controls
« Reply #27 on: January 19, 2020, 02:02:28 pm »
No decoupling wont help.
Yo u can use a speed up feedback capacitor from output to input (100pf )?
I have used this comparator in a LC meter and it worked up to 100KHZ fine.
Your waveform looks like the scope is on AC setting when it should be on DC.
One thing that hit but might not be a problem is your lower comparator input goes to ground which means other input has to go below zero which might latch it up. Might work or as is.
A slow moving input definitely needs hysteresis with a speed up capacitor.
Also any comparators I have used need pull ups on the output.
Online Gyro
« Reply #28 on: January 19, 2020, 02:11:13 pm »
Is anyone reading the previous page?  :-//
« Last Edit: January 19, 2020, 02:13:40 pm by Gyro »
Best Regards, Chris
Offline StillTrying
  • Country: Broken Britain
« Reply #29 on: January 19, 2020, 02:20:27 pm »
We've seen a few. I don't know about the OP's scope, but a scope's Y amp often has an AC coupled high frequency path and a parallel DC path. A lowish frequency square wave can show any mismatch between the Y amp's AC and DC paths.
Here's a bad one DC coupled @ 100 Hz, - now fixed.
https://www.eevblog.com/forum/testgear/siglent-sds1000x-series-oscilloscopes/msg1210795/#msg1210795
Nothing to do with the scope's AC/DC coupling switch, but switching to AC coupling can cause problems as well. ;D
https://www.eevblog.com/forum/chat/scope-acdc-coupling-at-60hz/
Offline StillTrying
« Reply #30 on: January 19, 2020, 02:24:55 pm »
The whole thread is surreal!
Offline ogden
  • Country: lv
« Reply #31 on: January 19, 2020, 08:30:32 pm »
Nothing wrong with this thread. We can learn alot about: 1) comparators 2) specifics of old analog scopes 3) people :)
