A great example of human laziness and AI failure!
The table I attached is created by ChatGPT, because I was too lazy to do it myself.
Apparently, the data used by the AI model is not accurate, and I should have checked better.
Also, another typo I made: the correct transistor type I want to swap is 2SC1382 and
2SA682. Apologies for all the confusion!! I corrected the title as well...
Anyway, I think I'll use BD139 & BD140 to replace 2SC1382 & 2SA682. They are the easiest to find in my area.
Digging a little further on my own I found that BD790,BD792 or KSE172 can also be used instead.
Is there any particular reason why I should chose a particular series over another?
Thank you
