Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Component checking in circuit
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Component checking in circuit (Read 675 times)
Crambone
Frequent Contributor
Country:
on:
December 18, 2019, 11:39:46 pm »
If I have 2ea identical surface mount boards and one is bad can I compare component (resister, capacitor.....) to the known good one to identify a bad part?
Example: I check C1 on good board and get 10uf and then check in bad circuit and get 10uf then I can assume that cap is good? Can I keep doing this part for part until I find one that is different and then assume that is the bad part or one of the bad parts?
Logged
GerryR
Country:
Re: Component checking in circuit
Reply #1 on:
December 19, 2019, 12:23:38 am »
I would think that taking measurements, while each unit was powered up, and comparing the voltages would give more accurate results (unless smoke has been released!).
But doing it with no power is a good start. If you have a way to inject a signal and chase it around, that would be another approach. Not knowing the circuit makes it difficult to know the best approach.
Logged
Still learning; good judgment comes from experience, which comes from bad judgment!!
Crambone
Country:
Reply #2 on:
December 19, 2019, 11:21:46 pm »
It’s an RCI 2995DX circuit ,
http://www.cbtricks.com/radios/rci/rci_2995dx/graphics/rci_2995_dx_sch.pdf
TP7 was grounded by accident with the mirror board out that normally connects TP7, 8 & 9.
Logged
GerryR
Country:
Reply #3 on:
December 20, 2019, 01:17:18 pm »
Looking at the schematic, you can check for continuity (Ohms) between Q60 collector and TP7 and continuity between TP7 and C219-C220-L26 junction, and compare the ohms readings to the good board. My first inclination is to suspect L26, but...
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
