Author Topic: Component identification  (Read 1059 times)
Offline lthrelfallTopic starter
« on: December 23, 2018, 02:46:39 pm »
Hello,
Can anyone tell me what this damaged component is in the attached photo, its on the logic board of a iMac 14,2?
I can't see any part number on it, but expect its the same as the undamaged one on the left, the connector below goes to the left hand speaker.
Any help is appreciated.
lthrelfall
Offline wraper
  • Country: lv
Re: Component identification
« Reply #1 on: December 23, 2018, 02:58:43 pm »
Common mode choke.
The following users thanked this post: lthrelfall
Offline David Hess
  • DavidH
« Reply #2 on: December 25, 2018, 01:27:03 am »
A agree; it looks like a common mode choke to protect against RFI which is a real problem with audio amplifier outputs.
« Reply #3 on: December 26, 2018, 08:32:34 pm »
Thanks for the replys,
Is it normal for there to be no id number on them? do you think its worth unsoldering the good one to see if theres any code on the underside?
Best,
lthrelfall
Offline wraper
  • Country: lv
« Reply #4 on: December 26, 2018, 08:40:29 pm »
Absence of marking is pretty normal. You could measure inductance and find a similar part. Replacing it with 2 separate ferrite beads would work too. Even using 2 jumpers would work, although there would be more RF emissions from the laptop.
