Author Topic: [Solved] LTSpice sim for toggle power switch is taking too long  (Read 3634 times)
Offline kasbahTopic starter
    • My electronics project sharing site, kitnic.it
« on: January 19, 2016, 01:45:52 pm »
Hey, not really a beginner but I don't use LTSpice that much.
I am trying to simulate the press-on-hold-off toggle switch circuit from this article (in auto-off mode).
The simulation is taking waaaay too long. Like it will never finish. Any ideas? LTSpice file is attached.
EDIT: To clarify, if I use a 18V DC voltage source, instead of one with an initial 18V pulse step the simulation finishes fine, but I don't think it's an accurate representation of the circuit and it doesn't behave as hoped.
« Last Edit: January 20, 2016, 10:20:09 pm by kasbah »
Share your designs on kitspace.org
Offline AlfBaz
Re: LTSpice sim for toggle power switch is taking too long
« Reply #1 on: January 19, 2016, 01:58:34 pm »
looks like it's having a hard time with the ground path. Try placing a 100Meg (Meg not M) from the anode of D1 to gorund
« Reply #2 on: January 19, 2016, 03:26:22 pm »
Brilliant! That did it. Updated schematic attached. Thanks very much.
« Reply #3 on: January 19, 2016, 05:40:29 pm »
Here is a simulation of switching on, pressing button for 1s without effect then holding to turn off, and then back on again. What do people think of this circuit? Any pitfalls?
« Last Edit: January 19, 2016, 05:44:37 pm by kasbah »
Offline K5HJ
« Reply #4 on: January 19, 2016, 09:24:50 pm »
For future reference, all nodes must have a DC path to ground.
Offline andre_teprom
  • Country: br
    • Aluis-Rcastro
« Reply #5 on: January 20, 2016, 09:42:35 pm »
Isn't the circuit nothing else than working as described in the original article?
"A momentary button press turns a power MOSFET ON, and holding it for a few seconds turns it OFF"
"Part of the world that you live in, You are the part that you're giving" ( Renaissance )
« Reply #6 on: January 20, 2016, 10:07:45 pm »
Yes, now it does. Originally I couldn't get the simulation to work.
Re: [Solved] LTSpice sim for toggle power switch is taking too long
« Reply #7 on: July 26, 2016, 02:28:11 am »
Sorry, to bump this but I turned this into a little a PCB and have quite a lot left over in case you would like one.
You can buy the right parts and download the Gerbers here: https://kitnic.it/boards/github.com/kasbah/push-on-hold-off/
« Last Edit: July 30, 2016, 03:04:09 am by kasbah »
Offline RogerFL
« Reply #8 on: April 06, 2020, 10:16:39 pm »
Old topic I know but I need a power switch circuit like this so here's an update.
I took the 3rd ltspice file from kasbah and thought it needed a load to be more complete, so I simply added a 10K resistor to GND from the output Vout. And then the simulation quit working.
Anyone want to try solving this again?
Attaching the updated sim.
Offline eblc1388
« Reply #9 on: April 07, 2020, 02:24:27 pm »
You can try the attached file. I tested the output with different loading from 10R to 100K.
« Last Edit: April 07, 2020, 02:26:35 pm by eblc1388 »
The following users thanked this post: kasbah
