for an amplifier im designing i want to know the dc offset on a signal as a 1:1 output voltage (a circuit that outputs the dc offset voltage without the signal). My idea was to have a differential amplifier set up as a buffer on either side of an ac coupling capacitor. Would this make sense as an applicable circuit? or are there better ways of getting the desired result?
