Hi everyone,
I have a problem with my circuit where a transistor keeps frying, and I don't understand why ...
Here's my circuit :
http://tinyurl.com/29vbmd3I have a 12DC source, and 2 switch mode power supplies. One outputs 3.3V/0.5A (to an LED, and a PIC not shown), the other outputs 24V/1A, for a solenoid valve . Eventually I'll have the PIC control my valve, but for now I just connected the valve as shown in the diagram to make sure things are working ...
At the bottom of the diagram I implemented a transistor switch using the ZTX1048A NPN transistor (
http://tinyurl.com/2azppvc), which according to specs can handle Ic of 4A. I chose the resistor value for R1 to be 4KOhm so the transistor Q1 saturates.
When there is no valve connected, everything works great. I turn on my switch, the 3.3V power supply turns on my LED (drawing about 16mA), and it powers my PIC and LCD just fine too. Great. When I connect my valve as shown in the diagram and turn my switch on, the LED turns on for maybe 1/4th of a second, and during that time I can hear my solenoid valve open and then close. Then, unless I immediately turn my switch OFF, my transistor Q1 starts smoking and then it just dies. While the LED is ON for that short time, it also makes some vibrating sound ... don't know why.
The valve's specs say it wants 24V and consumes 6.9W :
http://www.valvestore.com/prodinfo.asp?number=42703So that's less than 300mA of current.
- Why is Q1 frying ?? It seems to me that it should be able to handle the current going through it.
- Why is my valve causing some vibration on the LED ?
Thanks a lot !
Pierre
