Author Topic: Why Do Blister Packs With Button Cells Need Air Vents?  (Read 4040 times)
Offline Boris_yoTopic starter
  • Country: il
« on: April 19, 2013, 01:07:06 pm »
Ordered these from China and noticed blister pack has air vents (see attached picture). Why do button cell batteries need these? I didn't notice same vents on AA battery backs.
Offline Rerouter
Re: Why Do Blister Packs With Button Cells Need Air Vents?
« Reply #1 on: April 19, 2013, 01:14:25 pm »
i would assume its more for the packaging, as the difference from sea-level especially by airmail could crinkle or partly break the seal on the packaging otherwise
« Reply #2 on: April 19, 2013, 04:16:00 pm »
It is for the sealing of the cells into the packaging, as this is done with a heating pad that presses down onto a sheet of cardboard that in turn is pressed down onto the plastic blisters in a jig. No air holes means you get collapsed blisters when you remove the packaged unit from the jig as the air inside the blisters cools rapidly and the card is coated with a thermoplastic film that melts to seal to the blister PVC. Expensive for the tooling ( or you make them in wood) and the ejector pins are very expensive, and last only for around 10k of operations.
Offline gibbled
  • VE7 call sign
« Reply #3 on: April 19, 2013, 11:44:12 pm »
I always thought those holes were for probing to check if the battery still holds a charge without opening the package.
Offline Psi
« Reply #4 on: April 20, 2013, 12:26:05 am »
I thought they were just a hole to use your finger and tear the cardboard away with.
  • Country: il
« Reply #5 on: April 20, 2013, 08:09:28 am »
Is doing this possible without opening the package? How can this be done? I can only assume this can be done with multimeter.
Offline orbiter
  • -0 Resistance is Futile
« Reply #6 on: April 20, 2013, 11:26:11 am »
You'd have to have a pretty good probe to get through that hole & then round to negative side of the battery to complete the measurement :D
Offline Fsck
  • sleep deprived
« Reply #7 on: April 20, 2013, 11:29:03 am »
ditto.
"This is a one line proof...if we start sufficiently far to the left."
Offline gibbled
  • VE7 call sign
« Reply #8 on: April 23, 2013, 01:50:29 am »
Lol about the pretty good probes, my blister packs are also perforated on the blister side.  Very probe friendly... 8)
Offline Razor512
« Reply #9 on: April 23, 2013, 02:33:28 am »
I feel they are for probing also,. They came in handy at the store when I had to buy a replacement battery for a motherboard, and I did not want to wait for a shipment.
Many stores do not sell those batteries very often and will have lots of old and to get one that was at the proper voltage I have to test about 4 different batteries. (Most were in the upper 2V but I was finally able to get one that was at 3.26V which is where cr2032 batteries are at when they are mostly fresh and not shitting on a shelf since the paleolithic age)
Offline amyk
« Reply #10 on: April 23, 2013, 06:49:10 am »
Those are definitely for probing.
Offline G7PSK
  • It is hot until proved not.
« Reply #11 on: April 23, 2013, 09:18:54 am »
I also thought that they were to ease the removal from the packaging, but my experience is that you still need industrial power tools to complete the removal.
