If you want to read the ohmic value of an unknown resistor, it's easier if you have a constant current. The equation is R=V/I. If your I is constant then you only need to measure voltage to get the resistance. If you have a constant voltage then you measure the current. If you don't have neither constant voltage nor current you measure both.
