yes i used 2 amp meters in line between the shunt, it showed .01 difference between the meters.
not sure what else needs to be seen, simply reading the analog reading off the current monitor.
You haven't even told us what voltages you are getting from the sensor. If you measure the output voltage for at least two known currents (e.g. 0 and 2.25Amps) and plot the transfer function, are you saying this falls outside of the datasheet specification? Ignore the rest of your system entirely, since we know nothing at all about it.
Sorry,
not trying to be difficult, not really sure what needed to be provided.
this thing is hooked directly to an arduino via the 5v/Grd/A1 input ports.
at 0 current it reads 2.5v which is perfect.
the load which is a simple spring is feed power via a current controlled PSU.
readings from both meters, were showing 2.25 amps. the shunt showed about 1.51, and it scaled roughly the same through the entire range i could try 500ma-5 amps
from some reading this appears to be normal that a correction factor is needed.
