E.g. a 10 inch by 8 inch boards with lots of very wide high current traces did not work for me, it proved impossible to get the layer of toner thick enough to work properly even though the Pulsar paper transferred all of it to the copper.
I used to have this problem, as do many others. But no more. I suspect there are two issues at play that make this pronounced, which I'm thinking it MIGHT not be your printer. My problem disappeared, no change in the printer.
1. the toner isn't fully fused to the board and/or the laser printer pattern is leaving tiny gaps in w/e dot matrix it leaves... due to the mechanicals or software or w/e. You can see this on the print under a microscope.
2. etching with acid peroxide
I think what happens is acid peroxide will get into any weak point in the resist and undercut like mad, leaving pin holes in your ground pours. I don't use any foil overlay and I get solid pours without any problem, anymore. I'm not sure which of the two is the main culprit,* but my method eliminates both. I fuse the toner to the board at high temp to completely liquify it, and I pre-etch the board so the toner doesn't wander. The "dots" fuse together, but the fidelity remains very good. And I abandoned acid peroxide. Try making a sharpie board in acid peroxide, and you will see the same sort of problem, but even worse! With a proper etchant, the board will be night and day better, and you simply don't spend (waste) time inspecting the board for shorts and broken traces and making repairs.
*I can still see some "spots" on pours after the etching where it looks like the etchant got through gaps in the resist; but they are very shallow/superficial. After a shine with steel wool, they are gone, and I have solid planes and traces with crispy edges. So it might be a matter of degrees. Suboptimal etchants and/or transfer method add up and cause problems on a continuum between "it works" and perfection.
I remember seeing pics of DIY boards that were way better than mine and thinking that it was a matter of practice.** And mine were good enough for what I needed, at the time. Then my needs changed, and the boards didn't get any better with just practice. I didn't luck out and start out making good boards; I started in the gutter, and I have a pretty good idea of what makes the differences.
**Or that the board was cherry-picked out of a dozen!
Nope. Every board, every time. And it doesn't take skill or practice. Just the aquisition and application of knowledge.
