Author Topic: Bench Power Supply From ATX  (Read 8401 times)
Offline SamyazaTopic starter
« on: April 09, 2016, 07:42:56 am »
Hello, I'm new to electronics. I own two compaq ATX power supply to be specific the: Compaq ps-5201-4t2.
I tried to find schematics on the web but without success.
It has a 20 pin P1 connector. I tried to use a generic pinout for a general ATX power supply but is not starting without the mo-bo connected.
I thought it needs some loads, so I used 10 Ohm 5W resistors on 12v and 5v rails. Still nothing.
I also tried to put such load on the 3,3 V rail from the P1.
As I said the colours of the wires are different, but I tried them by analogy.
Whatever I do, I can't start the power supply. Any ideas?
I'm quite disperate. I want to use it to make a bench power supply.
Can anybody tell me the pin configuration of the 20 pin compaq PS-5201-4T2?
I've seen they are using separate colour form a standard 2o pin ATX power supply.
They are the same pins but with different colours?
Where should I put loads to start it without the mo-bo?
Thanks!
Offline jeroen79
Re: Bench Power Supply From ATX
« Reply #1 on: April 09, 2016, 10:58:32 am »
« Reply #2 on: April 09, 2016, 08:29:42 pm »
I grounded the PS_ON but is not starting.
Also I tried to use 10 Ohm 5W resistors as load on some rails, like the +5 +3,3 +12 and nothing.
Other ideas?
Offline jeroen79
« Reply #3 on: April 09, 2016, 11:19:01 pm »
Can you measure voltage on the 5V AUX line?
« Reply #4 on: April 10, 2016, 08:17:50 pm »
nope is not working.. is 0
Offline prawncrackers
« Reply #5 on: April 11, 2016, 07:22:04 am »
maybe its damaged? why dont you post pics of the board and maybe we can find the fault if it is damaged.
btw some ATX PSUs have ATX-specific controller ICs which monitor the 3.3v 5v and 12v outputs and will report a fault if the voltages arent right in all 3 pins. that makes it hard to modify the output voltage. ATX PSUs with TL494 ICs are easily modifiable.
« Reply #6 on: April 11, 2016, 08:23:42 am »
No is not damaged.. I have two of them and both have the same problem. Is the only atx source model I couldn't start without mobo!
I need to find a way. I want them to make a power bench power supply. I need like two of them. One made from an ATX power supply and another made from a switch mode power supply 24V and 10 Amps. For the other is a little bit complicated with the voltage control and current limiter.
The problem is the LM317 is not working over 2-3Amps, the LT1038 is obsolete and nowhere to be found so I went over this schematic:
http://electronics-diy.com/electronic_schematic.php?id=981
This solves the voltage regulation but... I idon't know what to do about the current limiting.
I need a knob to fix the maximum current for an app and for both of them of course I'll have displays, actually a voltmeter and an ampermeter. The LCD type. In fact I found a nice combo. 0 to 100V cc and 0 to 10Amps in the same enclosure. neat..
Offline Grayfox
« Reply #7 on: April 11, 2016, 08:25:01 am »
The wire you are grounding is green PS_ON right?
Not the gray PWR_OK
Try connecting the PWR OK to a red LED with a 220ohm .5w resistor to add some load to it
Think I read that the PWR OK needs to get some kind of signal to keep the PSU on, I know it tells the mainboard that the power output is fine.
Also  you said this is a compaq PSU
Saw this so your pinouts may not be to the ATX spec
« Last Edit: April 11, 2016, 08:27:20 am by Grayfox »
« Reply #8 on: April 12, 2016, 06:12:50 am »
is a 20 pin P1 not 24. I will try today with the power ok wire.
Offline Grayfox
« Reply #9 on: April 12, 2016, 07:01:43 am »
The other 4 pins are
+12v, +5v
3.3v, GND
Pin 14 is PSU_ON in both 20 and 24 pin ATX connectors
It is a wild shot by try connecting the PWR OK to PS_ON#
It might turn on, but I wouldnt rely on this for long term, but doing it for a second should be fine.
« Last Edit: April 12, 2016, 07:09:12 am by Grayfox »
